propane
Old 08-21-2005, 05:09 PM
why165's Avatar
why165
why165 is offline
propane
i know there is a web site that lists what you need and how to put propane on your truck, i just cant find it. please put that link up
thanks
matt
Old 08-22-2005, 05:33 PM
Dieseldan7.3's Avatar
Dieseldan7.3
Dieseldan7.3 is offline
You can go to ziggsters link, just look up ziggster on google.com
I did a system similar to his, just simpler but it works the same. Mount a gas grill tank in your bed and get an acetylene regulator, it will screw right into the tank. then run a hose to a shut off solenoid. it can be bought at RV dealer. Wire the solenoid so it comes on at half throttle when the switch is turned on. I used a push button switch mounted on the ip and then a lighted rocker switch on the dash.
From the shut off solenoid run the hose to the air filter container.
Look at ziggsters for the details but its fairly simple and I got by for a $120.
I have some pics of it in my gallery.
Old 08-23-2005, 09:52 PM
Dave Barbieri's Avatar
Dave Barbieri
Dave Barbieri is offline
Go to Rudy Axelrod's webpage and print his booklet on installing a propane fumigation system on a Ford F-series diesel truck.
http://www.pacificwi-fi.com/htm_booklets/ford/
Great information!
77f250400
06-11-2010 07:55 AM
cbusbronco
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-30-2009 01:57 AM
rstorm
03-25-2008 04:09 PM
mmmPowerStroke
02-07-2005 07:37 PM
akita
03-29-2004 08:55 PM
Quick Reply: propane
