ignition makes clicking noise, won't turn over, is not the battery
This is a '93 Ranger with the 2.3L 4 cyl engine- the ignition lock and the starter solenoid were both replaced but it still won't start. The starter solenoid makes a "clunk" sound, it doesn't make the "tick-tick-tick" sound like a dead battery, it has plenty of juice in the battery. Any suggestions, or how do I trouble-shoot the ignition at this point? Thanks for your help.
Do you mean the starter solenoid that is on the starter or the starter relay on the fender is making the clunk sound? If you are talking about the solenoid on the starter I would take the starter to a local parts place like Napa or Advance to get it tested.
I have a 95 mazda 2.3 and every now and then when I try to start it the starter relay on the fender will make one loud click and not start. After a couple more tries it will start with no problems. I am leaning towards the relay on the fender or possible ignition switch. My starter is only 4 months old and the battery is fine.
The first thing I did was check and clean all of the cables and connections from the battery to the relay to the starter. It still does it once in a while and it is hard to trace when it works most of the time.
We replaced the starter relay on the fender, and the ignition lock cylinder. We cleaned the battery terminals and tested the battery, which tested as a good battery. We haven't gotten down to the starter or the starter solenoid. There's no easy way to check the starter without removing it, is there?
mOROTBREATH
18
09-24-2013 07:01 PM
JoeSwing78
34
08-23-2013 05:53 PM
rneutron
04-09-2005 09:46 AM
