1983 - 2012 Ranger & B-Series All Ford Ranger and Mazda B-Series models
Where is the fuel pump relay/inertia switch?
Old 08-03-2005, 07:17 PM
hawki_peers's Avatar
hawki_peers
hawki_peers is offline
Hey everybody, I hope that all is well. Just wondering if you could help me with something before I drive to Minnesota from Toronto.....I am having a fuel flow problem in my 1998 MAZDA B2500, and would like to test the fuel delivery system. Please let me know (Haynes is useless as usual) where the fuel pump relay, and the inertia switch are. Also, a simple system test explanation would probably help me tonnes. It seems like when I start the truck cold, it bucks for about 30seconds, then finally breaks 3000 rpm and is able to accelarate. Also, when on the highway I have intermittent loss of power. Any suggestions would be GREATLY appreciated. THANKS!!!
Old 08-03-2005, 08:30 PM
hawki_peers
I found the inertia switch, it seems OK. Anybody able to help me with a possible diagnostic for my problem? Thanks!
Old 08-03-2005, 11:50 PM
el conquistador's Avatar
el conquistador
el conquistador is offline
I would pull the codes and check the fuel pressure when the truck is having problems. you can probably get the codes pulled at autozone or the such, pick up a fuel pressure tester while you are there. Also, how many miles are on the truck and when was the last tune up?
Old 08-04-2005, 10:45 AM
pintopower8's Avatar
pintopower8
pintopower8 is offline
I had the same problem in my Ranger 2.5l it was the mass airflow sensor. Thats what I would check first. It would bounce around for a while then idle smooth back and forth. I could drive it but it would cut if I didn't keep revving it. Hope this helps
Old 08-04-2005, 10:52 AM
RangerRuss's Avatar
RangerRuss
RangerRuss is offline
Clean your MAF sensor real well with some non-residue electrical cleaner.
If you have not cleaned your throttle body recently, that would be a worth while exercise. Use air intake cleaner. Do not use carburetor/choke cleaner.
Keep us advised
Russ
Old 08-04-2005, 11:01 AM
1081's Avatar
1081
1081 is offline
Don't forget to change the fuel filter also if it hasn't been done in the last 15,000 miles or so. I just changed mine after 75,000 and oh what a difference it makes. At least you would have better gas flow!
<a href='http://www.smileycentral.com/?partner=ZSzeb008_ZNxmk146YYUS' target='_blank'><img src='http://smileys.smileycentral.com/cat/36/36_11_12.gif' border=0></a>
Old 08-04-2005, 10:44 PM
Wildpony2000's Avatar
Wildpony2000
Wildpony2000 is offline
Where did you find the inertia switch ? Is this the same as the emergency fuel shutoff in case of an accident ? Mine is supposed to be at the top of the carpet on the right of the hump according to my owner's manual that was still in the glovebox but I can't locate it there or at the kick panel. Is there a pic somewhere ?
Rich
Old 08-05-2005, 11:09 AM
1081's Avatar
1081
1081 is offline
I had three for vans and they were behind the kick panel on the passengers side. On some you can reach over the panel with your fingers and feel it, but keep in mind that this switch won't restrict fuel flow, it cuts it off in case of an accident.
Old 08-05-2005, 07:47 PM
Ken00's Avatar
Ken00
Ken00 is offline
The inertia switch is the fuel cut off, just as you thought.
Thats were it should be, do you have any home spliced wires in that area?
Old 08-10-2005, 06:32 PM
Wildpony2000
It appears I do have spliced wires by the kickpanel. How many wires are we talking about and what are their colors ?
Old 08-10-2005, 08:18 PM
Ken00's Avatar
Ken00
Ken00 is offline
I would expect two wires, maybe brown/red or red/brown.
Old 08-10-2005, 08:47 PM
Wildpony2000
Thanks, Ken.
These are Orange with a blue stripe connected to a pink with a black stripe. There is also a multi wire connector with nothing attached to it at the top of the hump.
Rich
Old 08-11-2005, 01:12 AM
irishguyincc's Avatar
irishguyincc
irishguyincc is offline
Heh, I've been fighting with this kind of problem for months with my '87 Ranger. If someone has bypassed the wire that goes from the fuel relay to the inertia switch it is probably because the plug that goes into the switch is fried, as mine is. If what I described is the case on your truck try unplugging the plug from the inertia switch and see it the truck runs any better, it helped me for a while. One thing I learned is that you must leave the wire running from the relay to the end of the inertia switch plug intact. I tried splicing a line directly from the fuel relay to the line that runs from the inertia plug to the fuel pumps. The pumps had no power. When I put the line I had cut (the one from the relay to the plug) back together the pumps worked again, even with the plug unplugged from the inertia switch. Just FYI, hope that wasn't too confusing...
Old 08-11-2005, 03:26 PM
Wildpony2000
Hey Irishguyincc,
I have an 86 ranger. What color are your wires to the switch ?
Rich
Old 08-11-2005, 03:51 PM
irishguyincc
My wires appear as follows: from fuel pump relay it's a red with green stripe, in the cab the wire from the relay to the inertia plug is orange with light blue stripe and the wire from the plug to the fuel pumps is pink with a black stripe.
Quick Reply: Where is the fuel pump relay/inertia switch?
