VIN Help Needed!
VIN Help Needed!
Hi fellow Ford fanatics! I'm new here (but not to Fords). I just aquired a nice 1963 Econoline Club wagon, and need some help decoding the VIN. Here goes:
WB C Model Body Trans Axle
090 E E130 89D A 01
Warranrt info is:
E13TH367587
Thanks, and I am glad that I found y'all and this forum!!!!!
Jerry
jerryS@pdalightingandsound.com
090 E E130 89D A 01
Warranrt info is:
E13TH367587
Jerry
...Welcome Jerry, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
Ok here goes. The E13 is model E130 Deluxe Club Wagon.
The T says you have a 170cid 6 cyl.
The H means it was built at the Lorain assembly plant.
The remaining numbers mean the consecutive unit number, meaning which month and what number of unit that was built that month.
Does that help any? Have fun and enjoy driving your wagon.
Originally Posted by 66gpw
A on the trans means c4 Automatic.
They certainly did not get the C-4 auto in 1963.
89D is the Club Wagon. 2923 produced in 1963
I'm not sure about the engine and what the "T" means for sure. There were only 2 engines available in 1963, the 144 and the 170. Look at the door tag. The engine HP will be listed. The 144 had 85 HP, the 170, 101 HP.
In 1963, the 144 was painted Ford Medium Blue, the 170, Ford Red.
I have a manual for 61 and 65 Econolines. It shows an S for the 144 and aT for 170 6cyl. I know I read the trans code from my 65 manual and it showed that to be an Automatic. I will admit I myself question this, for I beleive the Automatics came out in 65 or 64 but not prior to that. So I would stand corrected then.
Jshira If yours says T for engine and you have a 144. Has the engine been changed on your econo at some time?
I have 2 64's and 2 67's and one is a 4 spd on a 170 engine in the 64 van.
Anyways I do not have a manual on 63 and I deciphered what I could from the 2 manuals I do have.
Here is the 1963 Econoline brochure.
http://www.falconman.com/fullbrochur...llbrochure.htm
The auto and 4-spd. were not available until 1964. The only tranny available in 1963 was the 3-spd. Tranny code A.
The 144 had 85 HP. The 170 had 101 HP. The door tag on Econolines lists the HP. My door tag says 85 HP and I have a "T" engine code. Based on that, the "T" means the 144. Even if the engine has been switched, the tag would still be accurate.
here you go guy's, straight from the econoline registry!
E13 = Falcon Deluxe Club Wagon
T = 170 engine
H = Lorain assembly plant
367587 = December 1962 serial # - 1963 model
090 = wwheelbase
E = Viking Blue paint
E130 = Falcon Deluxe Club Wagon model
89D = Falcon Deluxe Club Wagon body
A = 3 speed transmission
01 = 3.50:1 light duty axle (7-1/4 inch)
? = missing sales district code
jim
T = 170 engine
090 = wwheelbase
jim
Thanks Jimbare. and Jschira. I have quite soon knowledge on these vans, but there is always room for more. One would be to eventually learn what disc brakes can be setup on these vans and trucks.
Looking forward to the day I restore the one truck and the customizung of the other. Thanks again.
