F250 PowerStroke Loss in Power ... Help?
I have read through the many helpful postings ... and think i have narrowed down my problem (i think) ... Here are my symptoms: truck cranks fine, idles fine, when reving up it hesitates and jumps, when putting in gear (manual) and pulling a slight hill it gets very sluggish and jumping smokes a little, when i turn it off i smell a little un burnt deisel in the exhaust pipe and surrounding air, when driving down hill and not pushing the pedal very much i can achieve speed. When on slight hill going up it slows and starts jumping and missing (i finally got it home) ... i checked the oil level, it is not completely full but not low enough that i would see to cause hpop problems. It has never stalled on me. My first thought was clogged fuel filter or water contamination. After reading through posting i think it may be the uvc harnesses.
Im just a shade tree mechanic and this is my first deisel. What would be the first thing i should check ... im broke.
F250 Powerstroke 1999 Superduty 112000 miles
Thanks
Greg
Thanks
Greg
...Welcome Greg, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
greg99,
i just installed an o-ring kit on my 2000. It takes a 1 1/8" deep socket with deep clearance (i believe it was 2 1/2") I used a black iron deep socket since they have more clearance. I show a pic or two of where it is and what is comprised. Try and plug the hole with a rag or something after you remove until you change o-rings and replace. the kit cost me $16 or so at Intl (1825806C92 IPR Seal Kit) but you should check to see if the same p/n kit applies to your 99.
hope this helps. see the pics...
I have an update ... i cranked the truck this morning to see if it still had the problem, i ran it up the road it felt like it was missing a little, steadily loss power as i tried to gain rpms .... later i replaced the fuel filter and gave it another test drive ...same thing but increasingly getting worse feels like a really bad miss ....barely got back into driveway ... i took out the IPR to see if o-rings were torn .. they seemed fine actually looked pretty clean and smooth still fitting very snug when i slid it back in. I put it back together and was just hoping that i unstuck something and it would run like a king ..... no luck it started up and i think if i had left it idleing for five seconds longer the motor would have broke off of the mounts rolled around in the yard and died.
Still no engine light, the conectors to the UVCs harnesses look ok no discoleration no hot spots, i have yet to take the VCs off ... trying to avoid it.
I have a feeling it is my HPOP or an oring or a bad fuel injector ANY IDEAS? Please.
Thanks
Thanks
Originally Posted by Big Red 00 F350
greg99,
Please always place an image as a link...it helps our dial-up members.
I appreciate it and so do they.
Thanks
HHHHEEEELLLPPPP!!!!! Please.
I have ohm out the 9pins on each VC gasket to find .8 ohms on all eight GPs and ~3.3 to 3.4 ohms on the injectors. There is no continuity to ground on the 5 middle injectors pins and no continuity to GP pins (outer 4) on either bank. ... Did not see any problems.
I STILL NEED HELP ...... PLEASE SOMEONE With any other possible suggestions.
Is it correct when the CPS goes bad it is just bad ... no gradual two day type deterioration. My engine idled fine would not increase rpm without jumping. It only hesitated/hickuped under load (pulling hill) absolutely no power .... next day could hardly pull it out of drive ..idling was getting worse ...replaced fuel filter checked IPR o-rings .... now it want even start ... sounds like it is trying to fire .. just jerks around. There is no SES light. Ive tried to pull pending codes .. there are none.
Could it be the MAP sensor?
Could it be the innercooler boots loose?
What other things can i check before i have take to the very expensive DR/Dealer?
Thanks
Greg
Thanks
Greg
