1978-79 F-150 4x4 Trac bar bracket...
I am doing a solid Dana44 conversion on my truck and trying to find a bracket I can use for the track bar.
I want to try and stay away from making one, for fear it will not be strong enough.
I'm hopeing I can get a bracket from some other vehicle, and make it work on my truck.
Thanks again
Wander thru a scrapyard until you find a likely candidate.
Otherwise sing the custom fabricator blues... -Hehe
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
I had a machine shop make me a custom trac bar and had the ends threaded so i could use large rod ends to attatch the bar without ever havint to deal with those darn bushings getting sloppy again. If you have, or can find a bracket to copy from its not hard to make. I had to make a bracket for the frame end of the trac bar because the factory bracket was too wide. you can buy the right rod end to fit the large bolt in the axle and use factory parts on the axle, makes for a really tight ride and if you go to a bigger lift, its adjustable
ronspolv
WTB - Parts & other
05-11-2015 06:38 PM
Highboy74
03-25-2014 10:32 AM
goodwrench1
13
01-16-2014 06:39 PM
BuiltFordTough302
16
06-05-2013 03:36 PM
