Oil splatters
Old 07-10-2005, 01:39 PM
blsd49's Avatar
blsd49
blsd49 is offline
Cool Oil splatters
I have a '49 F3 w/ flat 8. Oil or grease splatters from behind fan and pulley.
My manual says that no lube is required but my mechanic says it is?
Any input?
Brian
Old 07-10-2005, 04:07 PM
mtflat's Avatar
mtflat
mtflat is offline
Here's a link for the same question - I'm too lazy to type it over BTW 48-52 are the same
http://groups.msn.com/FordFlathead19...30105182447738
Old 07-10-2005, 04:57 PM
blsd49's Avatar
blsd49
blsd49 is offline
Thanks mtflat
I'm gonna' run up to the shop right now and check it out.
Thanks,
Old 07-10-2005, 06:33 PM
blsd49's Avatar
blsd49
blsd49 is offline
Looks like the oil is coming from the point on the hub where it mounts.
I did remove the screw and nothing dripped but was wet with oil.
Maybe it was overfilled and now most has ended up inside the hood and on the engine!
I'll keep an eye on it but am afraid I may have to pull it ...soooo tired of splattering oil!
bb
Old 07-21-2005, 11:09 PM
51ford fan's Avatar
51ford fan
51ford fan is offline
So, did you get the problem taken care of ???
Old 07-22-2005, 07:36 AM
blsd49's Avatar
blsd49
blsd49 is offline
Not yet....looks like I will have to take the fan and hub off , clean them and start over.
Just been super busy lately , but soon!
Old 07-23-2005, 12:38 PM
51ford fan's Avatar
51ford fan
You might want to install a repair kit from Mac's
Old 07-23-2005, 07:32 PM
blsd49's Avatar
blsd49
blsd49 is offline
I looked on-line and in my Macs catalog but didn't see a repair kit?
Old 07-23-2005, 07:54 PM
51ford fan's Avatar
51ford fan
Angry
Sorry, I have the 226 6 cylinder in my 51 with the fan on the water pump.and I totally forgot your 8 has the two water pumps with the independent fan, I'm brain dead I guess. I will look, and if I come across a kit for the fan I will let you know.
Look in Mac's Early Ford 1932 to 1948 catalog, they list Fan Spindle Mounting Bearing And Gaskets
Also LMC Truck Parts Catalog has the fan bearing and gaskets listed in there catalog.
Hope this helps
Rod
Old 07-23-2005, 08:07 PM
blsd49's Avatar
blsd49
blsd49 is offline
Not a problem. I will look at LMC. Thanks for the feedback.
Brian
Old 07-23-2005, 08:15 PM
51ford fan's Avatar
51ford fan
Wink
Brian
OK I found it I think, it's the Oil Filled Pulley And Hub Assy for a 48 to 52 Pickup. Part #21A-8603 @ $59.95
It's in the Classic Auto Parts Catalog www.classicautoparts.com Phone 800-654-3247
Old 07-23-2005, 09:21 PM
blsd49's Avatar
blsd49
blsd49 is offline
Wow ....you are fast!
I looked it up and that is the part.
Looked at mine and between the pulley and the mounting bracket (#'s 5 & 6 in the LMC catalog) there is what looks like a fiber type 1/4" gasket...that is where the oil is coming from. I don't see that called for in any catalog. I think that the mechanic who did the rebuild got some bad info when it came to that part. Other than this small but troublesome problem the engine is great.
I thought that it would eventually run out of oil to splatter but that doesn't seem to be happening. The mechanic will be back next week so I can ask him about it.
Thanks for all your help. I will order the assy.from Classic Auto.
Brian
Old 07-23-2005, 09:44 PM
51ford fan's Avatar
51ford fan
Brian, I'm glad to have been able to help you out. I work as a swimming pool operator for the city. I have Bell & Gossett pumps that transfer hot water from the boiler through the heating system. The pumps have an oil reservoir to lube the pump shaft. If I don't keep them full of oil they will seize up. I would hate to be out for a drive in your truck and have that fan seize. (just a thought)
Rod
Old 07-24-2005, 09:18 AM
blsd49's Avatar
blsd49
blsd49 is offline
Rod, And a good thought it is....I wouldn't really run it dry...just my frustration talking!
I ordered the assembly last night. Will let you know when I have it back on the road.
And hopefully soon some photos.
Brian
jgilrfr
27
12-28-2017 09:39 PM
TNT in Round Rock
03-30-2015 08:27 PM
Brian 2002
1999 to 2016 Super Duty
12-11-2014 04:38 PM
mjunk1
04-16-2014 06:53 AM
blsd49
02-28-2014 09:47 AM
Quick Reply: Oil splatters
