blocking heat riser for propane setup
Old 06-16-2005, 12:23 PM
eastvanmikee's Avatar
eastvanmikee
eastvanmikee is offline
I have a 79 bronco with a stock 400m wih a 425 impco propane setup.I remember reading somewhere that it is a good idea to block the "heat riser " to keep the intake manifold cooler, but I could not find any more info ie pictures or a more detailed description. I have the manifold off now to redo the head gaskets and would like to find out what is involved in doing this modification if it will gain performance or mileage..anyone know anything about it ??????
Old 06-16-2005, 12:47 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
With your 400 (no M) it is easy to do. All you need is a bunch of those copper kitchen scrub pads available from the grocery store. Pack them into the heat riser passage in the manifold as far as you can from both sides with a metal rod. You can also stuff them into the head passages. I have heard there are also some gaskets that close the passage but they might rot out over time.
Old 06-16-2005, 02:10 PM
eastvanmikee
wont the "scrubbies" still let heat/air through, or is the idea just to restrict the flow??
Old 06-17-2005, 01:47 AM
Torque1st's Avatar
Torque1st
Posting Legend
When you pack them in there there will be close to zero flow. You could detect flow with some instrumentation but it is as close to zero as you need.
Old 06-17-2005, 09:44 AM
eastvanmikee
thanks, will try it
Old 07-05-2005, 10:01 PM
yabbie55's Avatar
yabbie55
yabbie55 is offline
does this work with efi 351w
does it improve anything,
Originally Posted by eastvanmikee
thanks, will try it
Old 07-06-2005, 12:17 AM
Torque1st's Avatar
Torque1st
Posting Legend
Do not block the crossover with a gasoline engine with computer controls etc. This discussion was about a propane fueled vehicle. Check with the 351W engine forum for performance questions.
fabieber
17
11-16-2015 02:20 AM
fabieber
03-01-2015 09:22 PM
Feenba
08-13-2012 08:11 AM
jonnybronco
10-04-2007 10:18 PM
memattfish
01-13-2005 02:48 AM
Quick Reply: blocking heat riser for propane setup
