how often do you change your transmission fluid?
#31
Interestingly, though Ford recommends 30K fluid changes, they don't require the filter to be changed that often. The standard "filter" is really more of a screen.
IMHO, the best procedure is to install a pan drain and an in-line auxiliary filter (Ford #XC3Z-7B155-BA). This allows for easy fluid changes and better filtration, as well as easy changing of that filter. If you are blessed with a torque converter drain, you can do a very thorough job, but otherwise you can just do it more often.
#33
#37
Do you have a transmission temperature gauge? If not I would get one and change the fluid by how hot and many miles you drive. If the fluid stays below 165 degrees than change the fluid every 20k to 30k. Every 10 degrees of temperature take away 5K from the change interval. This if for normal ATF you can run synthetic ATF @ a higher temperature and longer change intervals.
#38
#39
Per Ford specifications, normal operating range for the 4R100 and 5R110 is 51*F to 248*F.
#40
Originally Posted by ford390gashog
the filter cannot take the extreme heat of the input line. thats why you use the output line it runs cooler.
The filter maker makes the following installation recommendations:
1. On new vehicles (less than 5,000 miles), it is recommended that the filter be installed on the cooler supply side to protect the cooler from contamination. On in-service vehicles (more than 5,000 miles), the filter should be installed in the return line from the cooler to the transmission. On any vehicle that has experienced any transmission difficulty, the filter should be placed on the return side.
http://www.emergingent.com/magnefine...ation_page.htm
#41
The issue is whether one wants to ensure that the cooler is not contaminated (so the filter is installed before) or one wants to ensure that the pre-existing contamination from the cooler doesn't travel back to the tranny. (so the filter is in the return line)
Since the filters carried by Ford are normally installed after some work on a tranny (flush/rebuild/replace/etc.) it makes perfect sense to put them after the cooler if the cooler is not replaced at the same time.
However, if one has an aged tranny (mine is over 170k) -- it makes a lot more sense to put the filter before the cooler, so if the the tranny breaks down, the filter will hopefully protects the cooler. If, or when, the tranny is replaced, the filter should be moved after the cooler, though, if the old cooler is to be kept in the car.
#45
On a gasser with not alot of pan volume, 15,000. On my PSD 30,000. Oil is way to cheap to sacrifice an AT. You also get a much better picture of what is going on inside you tranny if you pull the pan every 15,000. It's a lot cheaper to correct a problem, IE, clutches wearing, than wait til it grenedes to do a total rebuild. I will argue that a flush is the worst possible thing you could do to an automatic. Some people will swear by them, thats fine, keep on keepin on, if you change it every 15,000 you never have to worry about how much you got out.
Ryan
Ryan
