Where's the radiator drain plug on my '97 Expedition?
I want to drain & re-fill the coolant in the radiator of my '97 Expedition 4.6L. Does my Expy's radiator have a drain plug on the bottom? If so, how do I get to it? If not, is it ok to simply remove the lower radiator hose & drain it that way?
Thanks in advance for you's guys' help.
PaulC,
It's me again; I'm still having trouble finding the drain plug onmy Expy. It doesn't seem to be where you said it should be. I see some sort of plug on the lower right side of the radiator. What I mean by lower right side is: It's not on the bottom of the radiator & it's not on the back of the radiator. It's on the passenger side of the vehicle & on the side of the radiator.
The "plug" I see is an off-white, sort of yellow-ish colored plastic hex head screw of some type. The hex head is approx. 1/2"-5/8" tall. Am I looking at the right thing?
Thanks in advance
Thanks in advance
ilvtravln
04-14-2012 09:05 PM
