Minnesota Chapter Join Chapter, Leader: fordpower88
In need...84 Bronco parts heklp...
Old 05-23-2005, 09:48 PM
rick90yj's Avatar
rick90yj
rick90yj is offline
I need a gas tank for an 84 Bronco...does anybody here (Minnesota, near Anoka) have one? I got my Bronco home, and started playing with it, and when I poured some gas in the tank, it ran out the bottom...OOPS...
The boneyards don't sell them, they poke holes in them when they come in. OR, if you know of any other trucks that the tank will interchange. I put in a new fuel pump, and filter and it wouldn't start. I jury rigged a gas can to gravity feed the carb and it started right up. Thanks guys (and gals...)
I don't want any of this>>>
Old 05-24-2005, 05:17 PM
86f15035s's Avatar
86f15035s
86f15035s is offline
trucks n toys up here in cambridge will have one i just bought 2 tanks from them last year for my 86 f150
Old 05-24-2005, 06:50 PM
rick90yj's Avatar
rick90yj
rick90yj is offline
Do you remember what they charged you?
Old 05-25-2005, 06:57 PM
couleeman's Avatar
couleeman
couleeman is offline
You can get them from Ford as well. Mine installed with a new fuel pump was about $500 and the pump was $125 (newer style). If I recall correctly the tank was about $100.
Old 05-29-2005, 09:20 AM
Ford79's Avatar
Ford79
Ford79 is offline
Most auto parts stores should be able to get you one.
Old 05-29-2005, 11:00 AM
rick90yj's Avatar
rick90yj
rick90yj is offline
I know I can get one at an auto parts store, but that would double the value of the Bronco...they want $150 -200 for a new tank. I only paid $200 for it. I've found a used one for $50. Thanks for the replies.
Old 05-30-2005, 06:54 PM
86f15035s's Avatar
86f15035s
i also paid $50 each for my tanks from trucks n toys
Old 06-04-2005, 02:00 PM
rick90yj's Avatar
rick90yj
rick90yj is offline
gas tank...update...
Found a tank, and it's ready to go in. Thanks for the suggestions, I'll keep then in mind when I punch a hole in this one.
