New York Chapter Join Chapter, Leader: tiny1
C6 Help!!
Old 04-28-2005, 01:37 PM
ferrwrench's Avatar
ferrwrench
ferrwrench is offline
C6 Help!!
Launched my c6 on the way to work today....slips like mad. Anyone in the New England, Upstate NY area have one.. I would like a good used one, can't afford new, I think rebuilding is expensive. My truck is my daily driver, and this puts a damper on things. Any help would be greatly appreciated.
Thanks Chris
79
F250
2wd supercab
460ci
Old 04-28-2005, 02:18 PM
jwmustangman's Avatar
jwmustangman
jwmustangman is offline
The c6 is one of the toughest trannys on the market. Mabye yours just needs a tune up? when was the last time you changed the fluid/filter in it? sometimes that can make all the difference, and it is a heck of a lot cheaper and quicker than a tranny swap. I know on a rare occasion they can go out, cause I had to have mine rebuilt about 2 years ago. 2nd gear went out completely, but all the other gears worked fine. It never slipped or anything.
Old 04-28-2005, 04:19 PM
Fordbronco69's Avatar
Fordbronco69
Fordbronco69 is offline
Infidel
The band might need to be adjusted/tightend. Get a torque wrench and get under neath the truck. On the drivers side of the tranny where the kickdown/shifter controls are there is a band adjusting screw. Theres a lock nut and then the screw, losen the lock nut and tighten the screw to 10 ft-lbs. Back off the adjusting screw exactly 1-1/2 turns. Hold the adjusting screw from turning and snug up the locknut. See if it still slips. Get back to us. All information is from 365-127-79A Ford Truck Shop Manual.
I had a hard time finding my locknut/screw, was covered in dirt and looked like it was part of the transmission housing. It should be about 1"-2" directly infront of the kickdown/shift controls are.
Old 04-28-2005, 10:36 PM
Phinxter's Avatar
Phinxter
Phinxter is offline
before you do any of that stuff, check the fluid level first.
Diesel_Brad
11-07-2013 12:46 AM
rc.chris
1997 - 2003 F150
07-26-2012 11:43 AM
F-350PSD
02-21-2011 10:48 AM
Myf350sd
2009 - 2014 F150
08-26-2010 06:28 AM
CHACH
11-05-2003 07:08 PM
Quick Reply: C6 Help!!
