1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Changing Automatic transmission fluid
Old 04-09-2005, 08:54 AM
mldmkr1960's Avatar
mldmkr1960
mldmkr1960 is offline
Question Changing Automatic transmission fluid
I was about to change out my transmission fluid out now that Im at 30,000 and there is a nice drain plug on my transmission pan but I took the rubber plug out to drain the torque converter and cant find one there???? I removed the tin plate and cant find one there either? Is there one, kinda stupid if there isnt, was one on my 97 F150. This one is a 03 F350 with the 4R100.
Old 04-09-2005, 10:25 AM
Frobozz's Avatar
Frobozz
Frobozz is offline
No more torque converter drain plugs on the newer Superduties, sorry! Either drain and refill what you can (which is not as bad as it sounds if the fluid wasn't burned), or do the "pull the cooler return line and have the trans pump the fluid out for you" full-fluid change trick described around here somewhere or numerous places on the web.
Duncan
Old 04-09-2005, 11:35 AM
MRBASS's Avatar
MRBASS
MRBASS is offline
I have heard this before but My 02 has a drain on the TC, My neighbors 04 f250 also has a drain. Might try rotate the TC around and see if you can find it..
Old 04-09-2005, 02:18 PM
mldmkr1960's Avatar
mldmkr1960
Transmission fluid
No I went around it twice, what a pain in the a$$. Im doing it in the driveway, had turn it, roll around and check it, turn it, roll around and check it. I changed the fluid in the pan that was it for today. I will either try the other method of the return line or will just change the five quarts in the pan every time I change the oil. I can buy the Motorcraft Mercon at the dealer for $1.95 a quart so the price of it doesnt bother me.
Old 04-09-2005, 05:33 PM
superrangerman2002's Avatar
superrangerman2002
superrangerman2002 is offline
https://www.ford-trucks.com/article/...nsmission.html
Very usefull article written by Racerguy!
Old 04-10-2005, 05:48 AM
Lnd Svyr's Avatar
Lnd Svyr
Lnd Svyr is offline
Are you sure the dealer quoted the correct fluid. I called a couple dealers around my parts and they both said $4.60 a quart for Mercon SP and it has to be SP. Also, from reading about the drain and fill hereon, I believe it takes almost 10 quarts and a new external filter (dealers wanted $53.00 for the filter--got a Wix from filter1.com for $12.00 with shipping).
Old 04-10-2005, 07:41 AM
mldmkr1960's Avatar
mldmkr1960
Mercon fluid
There are three mercon fluids, Mercon, Mercon V, and a Mercon Synthetic. The one I bought was the Mercon that was what was listed for my truck regular Mercon, as what it said on the end of my dipstick. I didnt change the filter just pulled the drain plug on the pan and all I got out was about five quarts.
Old 04-10-2005, 07:56 AM
Casey's Avatar
Casey
Casey is offline
The article says it was written by Mark Kovalsky. Is that Racerguy?
I've used it several times. It works great!
Old 04-10-2005, 10:46 AM
Frobozz's Avatar
Frobozz
Frobozz is offline
Assuming "Mercon synthetic" is Mercon SP, then that is my understanding of the 3 fluids. Mercon goes in the E4OD and the 4R100 (like you said you have), while Mercon SP goes in the Torqshift. I don't know what Mercon V goes in, but it isn't a Superduty!
Duncan
Old 04-10-2005, 11:20 AM
snakebit's Avatar
snakebit
snakebit is offline
"I believe it takes almost 10 quarts and a new external filter"
Is there a external filter also? I changed the filter in the pan, I thought that was it.
Old 04-10-2005, 12:29 PM
mldmkr1960's Avatar
mldmkr1960
Filter
Yes the Torqueshift takes the SP fluid and has the external filter the one I have does not. BTW its 5.4, 350, 03 not a diesel.
Old 04-10-2005, 02:55 PM
tvsjr's Avatar
tvsjr
tvsjr is offline
Duncan
4R70W and I believe the 5R55E. Lighter-duty transmissions put behind the 4.6L V8 in the F150, Expedition, Mustang, etc.
Old 04-10-2005, 08:02 PM
snakebit's Avatar
snakebit
snakebit is offline
So is there an external filter on a 4R100? 03 CC 4x4 V10.
Old 04-11-2005, 07:44 AM
Casey's Avatar
Casey
Casey is offline
The 4r100 does not have an external filter from the factory.
kcoburn1
08-07-2015 04:56 AM
Drew2128
Escape & Escape Hybrid
01-07-2015 03:51 PM
My2000F250SD
03-22-2012 04:34 PM
90pioneer
08-28-2011 12:46 AM
rocky1074
08-29-2009 09:03 PM
Quick Reply: Changing Automatic transmission fluid
