4-speed Tranny Question...
your '86 has a hydraulic clutch, but it's an external slave cylinder. it only works the clutch fork. the ZF will require a concentric slave cylinder, which fits inside the clutch assembly. any ford 5-speed is like this. the only bolt-in replacement for the t-18 is a t-19 or NP435, both of which have a granny first and no OD, or the TOD/SROD tremec T170, which are both 4-speeds, with 4th being OD. anything else is going to need a clutch hydraulic system modification.
yeah, a TOD is a direct bolt-in for all 300s up to '86. '87 and up will need a bellhousing from an '86 or earlier. i prefer the TOD to the SROD because it's a top-mounted shifter, so shifts are more precise. other than that, they are the same. the casting code is RTS on the TOD, and RUG on the SROD. you might also find them referred to as the Tremec T170FT (TOD) and T170FS (SROD). hope that helps!
4speed tranny problems
i was wondering what the problem could be i have a 85 ford f250 4 speed 4x4 and it will move with all the gears but it makes a really bad wine noise and you can feel it i was wondering if that could just be low in gear oil or what could be the problem and it does have the 460 carb
It would help a little if you could start a new thread so people could keep track of what topic your talking about.
If you think it's low on gear oil, then check.
It's normal for the heavier 4-speed transmissions (T18, T19, NP435 etc) to make some whine in 1st, 2nd, 3rd, & reverse; 4th should be silent.
But if the noise is excessive, or you can physically feel the trans grinding over, something more serious is wrong.
I would check the oil anyway. There are two plugs on the side of the transmission - the upper one is the oil level.
HotLead
02-12-2015 05:03 PM
FordBronco4life94
45
01-23-2011 01:32 PM
alwaysmessedup
05-21-2003 01:55 PM
GregCS
03-05-2000 12:21 PM
