315/75/16/ on f350 daully
I have not done this, but I am quite sure you would need something along the lines of 4.5-5 inches to get the tires away from each other far enough so as not to have heat build up from them. The tires bulge past a regular rim by 2", so if you double that it would have you at 4" and that would have the tires on each other. You may have to see about finding a different off set for the bud wheels to get that size on the back. Good luck
shoobear, are you running those 315 on stock 6", or something else.
http://www.wheeladapter.com/default.asp
here is where i found my spacers
phil
phil
hey the only rim that i know of for the dually is a 6", the mtrs are suppost to be on a (I think) a 8" rim, but i run them on my stock rim. I know of a few guys that use this size on stock rims. They look good!
Hey i cant post pics, not sure why, if u want a pic of the my dually with the spacers installed send me a email. The spacers from ebay are a lower quality tha the ones from wheel adapters.com, i used the spacers from wheeladapters.com and when u install them u have to put the first wheel on, slide out the axle, put on the spacer, then slide the axle back in, and bolt on the outside wheel. Takes a few minutes more on each side but the spacer is made with a little taper on the inside dia and fits really good. The spacers ARE hub centric, the ebay spacers are not hub centric, they use a different wheel stud than your stock lug nuts and will have to buy nuts. The money u save on the spacers on ebay will go towards new wheel nuts. So hope this helps.
cheers
cheers
