Need help on a Holley 4160 rebuild.
This is my first time on a Holley rebuild and I have a couple of questions. Would appreciate any help. Carb is a Holley 4160. List #6919.
1. Replacing the accelorator pump - The diagram shows a check ball above the acc. pump but there wasn't one when I took the old one apart. Is this something that should be there?
2. Concerning the pump discharge nozzle - Diagram shows a "pump check ball weight" and a "Pump Discharge Nozzle Check Ball" below the pump discharge needle valve, neither of which I remember coming out. Are these absent on some models? or did I misplace them.
Thanks in advance.
HD
Thanks in advance.
HD
Yeah, I found em. The strap that holds the acc pump ball in had fallen out before I took the carb apart and was stuck between the metal and the diaphram in the acc pump. After spending hours searching the work bench and floor around it I decided to take a chance and dug the old acc pump out of the trash. There it was. Never found the ball but there was a replacement in the kit.
got the carb together and it runs fine.
Thanks
HD
Thanks
HD
Micbruff
23
11-05-2014 08:17 PM
redman84
17
05-29-2013 12:38 PM
