Cost for a rebuilt tranny for a 1995 F150
Old 03-09-2005, 03:48 PM
FORDRULZ666's Avatar
FORDRULZ666
FORDRULZ666 is offline
I have a 1995 F150 2wd that needs a new tranny. So how much would it be to get a rebuilt one and how hard would it be to put it on in my driveway. Also is there a heavy duty tranny for this truck that wouldnt be too much money. Thanks ahead for the replys.
Old 03-09-2005, 04:25 PM
andym's Avatar
andym
andym is offline
Manual? Automatic? What model are we talking about?
Old 03-09-2005, 05:10 PM
FORDRULZ666
Not sure what model but it is a four speed auto
Old 03-09-2005, 06:00 PM
FORDRULZ666
How can I find out what model it is.
Old 03-09-2005, 06:10 PM
tex94F250's Avatar
tex94F250
tex94F250 is offline
If it's a 4 speed auto in a '95, it's an E4OD. The cost of a rebuilt transmission varies from $1,200 to $1,600 depending on who does the work. What is the transmission doing? What doesn't it do?
Old 03-09-2005, 06:22 PM
FORDRULZ666
When you hit the gas it will go but very slow if at all. We had the computer checked thinking it was that and seemed to work but it is back now.
Old 03-18-2005, 08:38 AM
atvchick's Avatar
atvchick
atvchick is offline
You might check for a remanufactured tranny. You can sometimes get them cheaper than a rebuilt.
Old 03-18-2005, 10:50 AM
Ponyracer's Avatar
Ponyracer
Ponyracer is offline
There was also a four speed auto called the 4R70W available in that year. If it has a square pan with two rear corners cut off, it is the 4R70W. If it has a rectangular pan with a square cut out of one corner, it is an E4OD. It sounds as if it is starting in 2nd gear. when moving does it shift into any other gears? Does it seem as if the trans is slipping? What is the fluid condition and level? Did you get any codes out of the computer(PCM)? What engine do you have?
If it is an E4OD, there is a very common problem with the MLP/TR sensor on the drivers side of the trans. It gets moisture in side the connector and can cause all kinds of problems and no codes like the one you partly described. Pull the connector and see if there is moisture in it, if so it willl need replaced.
Old 03-19-2005, 06:22 PM
Ford_rulez19's Avatar
Ford_rulez19
Ford_rulez19 is offline
My truck did the same thing that yours did my seal went out and leaked fluid everywhere and it was in a busy part of the city too. I had it rebuilt cost me around $1,200 and i know i didnt get my moneys worth,but hey as long as it goes
Old 03-20-2005, 07:23 PM
donnor's Avatar
donnor
donnor is offline
auto trans codes
The transmission in a 95 F150 is probably the 4R70W, an updated electronically controlled version of the AOD. The door/post sticker code for this tranny is "U". Its overall length is less than that of the E4OD. If it is indeed an E4OD, the code is "E".
Hope this helps!
dn.
jonc123
06-01-2020 10:32 PM
1995 obs 4x4 dually
11-20-2014 08:41 AM
trevorrules
15
12-27-2013 08:49 PM
EdKay
12-13-2005 03:59 PM
wjtank
07-12-2002 10:47 PM
Quick Reply: Cost for a rebuilt tranny for a 1995 F150
