1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
rear differential oil
Old 03-07-2005, 02:15 PM
BlueKnight's Avatar
BlueKnight
BlueKnight is offline
I want to change both the front and rear differential oil on my 02 superduty. How many quarts of oil do I need to buy to do them both. Front is a Dana 60 and rear is a sterling 10.5
Old 03-07-2005, 02:36 PM
n578md's Avatar
n578md
n578md is offline
Dana 60 front axle: 90W gear oil, 2.7L or 5.8 pints or 2.9 quarts
Visteon/Ford 10.5" rear axle: 75W140 synthetic gear oil, 3.3L or 6.9 pints or 3.45 quarts + 8 oz of Friction Modifier type XL-3 if you have limited slip.
Transfer Case: Mercon ATF, 1.9L or 4 pints or 2 quarts.
Old 03-07-2005, 03:12 PM
SMiller's Avatar
SMiller
SMiller is offline
Ford says 3.45, but when I changed mine I seemed to get every bit of 4 quarts in the rear of mine, rear took 75w-140 syn.
Old 03-07-2005, 03:20 PM
Bear Hunter's Avatar
Bear Hunter
Bear Hunter is offline
I thought Ford changed the specs for the front from regular to synthetic?
DrDecay
04-04-2014 10:08 AM
recluse
10-29-2011 11:02 AM
jwhopson
22
04-07-2011 07:22 AM
sixgun95
01-25-2008 10:28 PM
swandog
04-22-2005 09:30 AM
Quick Reply: rear differential oil
