Valve Adjustment
Old 03-04-2005, 03:30 PM
ngneer's Avatar
ngneer
ngneer is offline
Valve Adjustment
New here folks, How do I adjust the valves on a 1990 2.3L 4 cyl. Thanks
Old 03-04-2005, 09:17 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE
…..See you on the boards.
Old 03-07-2005, 12:49 PM
Bart99GT's Avatar
Bart99GT
Bart99GT is offline
No adjustment is needed, you have hydraulic lash adjusters. If the valvetrain is noisy, one of them may need to be replaced or is gummed up. If you have a good OHC valve spring compresor (KD tools makes a great one that I use, I'll get the p/n off of it when I get home) you can try swapping them out yourself. They slide right out of the bores once you have removed the follower.
Old 03-07-2005, 03:26 PM
ngneer's Avatar
ngneer
ngneer is offline
Thanks Bart99GT, I have just bought this truck and know zilch abt it. I'm use to smallblks. of a different make. I will learn what I can abt. this one. Info on the tool would be great, also could you direct me to some info to read up on pertaining to this procedure you talked abt. above, again, 4 cyl. is Chinese to me, thanks again
Old 03-08-2005, 10:39 AM
Bart99GT's Avatar
Bart99GT
Bart99GT is offline
It is KD Tools 3087. Here's a link to an article on changing the valve guide seals on an SVO, but the same procedure applies for swapping out a bad lifter in our trucks, except you don't have to pull the valves out of the head. Just remove the follower, then pull the lash adjuster out of the head.
http://www.forced4.com/valveseals.html
JayzDaddy
05-29-2014 05:00 PM
merc62
03-09-2005 12:59 AM
DrkPhanstm
15
10-08-2002 05:52 PM
banjopicker66
05-26-2002 06:20 AM
Quick Reply: Valve Adjustment
