New Hampshire Chapter Join Chapter Leader: 7283-F250
Looking for air pump part... see inside
Old 02-26-2005, 01:33 PM
danwink's Avatar
danwink
danwink is offline
Hello all,
I am in the Portland area and in need of the H pipe (above the drivers side cylinder head) that connects to the air pump. I figured someone that has gone to headers may have one lying around. Checked the local boneyards to no success. I can send a picture of what I need if anyone has one.
1989 F250 351W
Thanks
Old 02-27-2005, 05:35 AM
dsldandually's Avatar
dsldandually
dsldandually is offline
sounds like a dealer item did you check the boneyard in westbrook by smiling hill farm I've had good luck there before
Old 02-28-2005, 03:18 PM
7283-F250's Avatar
7283-F250
7283-F250 is offline
So you need the pipe between the two exhaust manifolds or the part that comes off the pipe that the air pump hose connects to?
I got one of the screw things that goes on the pipe a few years ago at a parts store. If its the pipe your looking for I don't know. Possibly dealer or bone yard. Some yards will do a search and can possibly get one from another yard in another state(thats how I got a working air pump). I twisted mine trying to get the old screw off and used JB Weld to fix the hole I tore in mine and I than had to hack saw off the rest of the screw to get the new one on.
Good luck
Old 02-28-2005, 05:17 PM
danwink's Avatar
danwink
danwink is offline
dsldandually-- I did not check Westbrook- just Copp and another in North Yarmouth. I will try them.
7283-F250-- I think they connect to the exhaust manifold, it is an H pipe that sits up on top of the valley, to the drivers side (next to intake manifold).
I can get it from the dealer, but they only sell it as a whole replacement for $125, you can't just get the connector. Seems crazy to spend that kind of money. I did buy some JB Weld, that might be the solution.
Thanks for the help!!
Old 03-05-2005, 12:11 AM
fords8's Avatar
fords8
fords8 is offline
70mazie
Oregon Chapter
12-03-2014 12:46 AM
70mazie
11-25-2014 05:07 PM
ras4434
04-07-2009 06:27 PM
Jodell
Performance & General Engine Building
04-05-2008 12:31 PM
Quick Reply: Looking for air pump part... see inside
