Just how big IS a 534?
Old 02-24-2005, 12:08 AM
82F100SWB's Avatar
82F100SWB
82F100SWB is offline
No drawing, but here's a pic:
The oil pan is off, and those are 8x8's it's sitting on... That Holley looks mighty tiny on that HUGE old engine.
Old 02-24-2005, 08:31 AM
Ogrebonz's Avatar
Ogrebonz
Ogrebonz is offline
I got the stats from the other post, thanks! Ogre.
Old 10-30-2005, 07:59 PM
yalincoln2's Avatar
yalincoln2
yalincoln2 is offline
hello; you'll want to use a late engine, the early 534's had the intake runners in the head. the latter ones used an individual runner intake. at least you'd be able to smoke the tires from light to light, wayne.
Old 10-30-2005, 10:21 PM
witdog2020's Avatar
witdog2020
witdog2020 is offline
Old 11-08-2005, 06:27 AM
Still in the 60's's Avatar
Still in the 60's
Still in the 60's is offline
I have put a 534 into a 65 F-350. This is my experience, these dimensions are approximate.
It does out weigh a 390 by maybe 350 pounds, it is also 3-4 inches wider, taller, longer.
I raised the entire cab & fenders 3" on the frame, and brought a small doghouse 2" back into the firewall.
I think you will find on your 75 350 the steering gear will be in direct conflict with where the 534 exhaust manifold wants to be.
As far as the tranny, I think you will find that a very heavy unit must be used. The bell housing was unique to the Super Duty engines. Don't know that you would come up with a clutch and housing to use the smaller medium duty trannys
If you are going to use the truck much, the advice to use a 460 is good. MUCH easier to install.
If the goal is the doing as much as the result, have fun!
If you want any more details about my experience, glad to help. Sorry, no pictures yet.
With enough time, money & effort most anything can be done.
Jim534
New Member Introductions
12-09-2016 09:40 AM
jonnydesert
401, 477, & 534 SD Engines
03-11-2009 09:36 AM
mrautocar
04-14-2007 10:49 AM
beegeezy
29
10-05-2006 08:13 PM
TheNomad
09-24-2004 09:51 PM
Quick Reply: Just how big IS a 534?
