Just how big IS a 534?
Old 02-17-2005, 10:39 AM
Ogrebonz's Avatar
Ogrebonz
Ogrebonz is offline
I know I'm not the first to ask, but I couldn't find it in the archives. I'm building a '75 F-350 and wondering if a 534 will fit in there and what trannies will bolt to it. It's a frame up re-build of the truck, so now's the time to consider such things. IF anyone has any dimensional drawings or spec. for these engines I'd really appreciate seeing them. Thanks, Ogre.
Old 02-17-2005, 12:03 PM
rusty70f100's Avatar
rusty70f100
rusty70f100 is offline
The SD series 534 is a big, humongus, heavy, gas-guzzling engine, from what I've heard. Upwards of 1,000lbs. You might be able to make one fit, but it'd be a PITA IMO. However, you would get superb low end torque for towing, or whatever other work you plan to do with the truck. Plus, the "wow" factor of having possibly the biggest gas engine ever put in an F350.
I'm sure someone will come along with more specs.
Old 02-17-2005, 08:34 PM
glennbin's Avatar
glennbin
glennbin is offline
534 weighs in at 1032 lbs. Engine spec sheet to follow
Old 02-17-2005, 08:56 PM
Ogrebonz's Avatar
Ogrebonz
Ogrebonz is offline
Holy crap! 1032 lbs? I'm still thinking it'd work, those "D" trucks use that cow of a Cummins B motor, those are almost that heavy. Ogre.
Old 02-17-2005, 11:53 PM
magicbus's Avatar
magicbus
magicbus is offline
A 534??? Thats what we run in my dads crane truck that weighs 30,000 lbs. If thats what you want, then good luck and have fun, but that thing is going to DRINK gas. We figure we get about 4 miles a gallon, although that truck does have a lot of stand-still loading duties that consume gas which are included in that number.
Old 02-18-2005, 12:50 PM
Ogrebonz's Avatar
Ogrebonz
Ogrebonz is offline
Well, the 390 in my 2wd F-350 gets between 7 and 9 mpg, how much worse can it get? Ogre.
Old 02-18-2005, 06:28 PM
glennbin's Avatar
glennbin
glennbin is offline
Talking
I've got the 534 in my boat, ripped out the gov.,boxed the carb and turbo-charged it.
It's hooked up to 2-1 ratio capitol gear, I'm hoping for a increased heart when I punch it.
Still trying to figure out how to post a copy of the installation spec sheet,it will show up, I think
Old 02-18-2005, 06:32 PM
Kruse's Avatar
Kruse
Kruse is offline
This swap sounds good on paper, but there is a better choice, the stroked 460. The 534 has NO speed parts available. NONE. The top RPM range is about 3300. The parts that you still can get for it are extremely expensive. (I got a set of 534 cast pistons somewhere in the garage. I'm sure if I had to buy them over again, it would be ~$450.)
Now the 460 has all kinds of speed parts, including stroker kits that can get you over your 534 cubic inches. There is simply no comparison.
Plus, I won't even harp on the weight differences.
Old 02-19-2005, 10:44 PM
Ogrebonz's Avatar
Ogrebonz
Ogrebonz is offline
Well, considering you can buy a rebuilt 534 for about $2,600.00 plus a core the price of a "built" 460 seems a bit high. I realize it's not a pratical idea, maybe not even too smart. But come on, anyone can build a big block... Ogre.
Old 02-20-2005, 09:01 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
the 534 had a bell housing pattern some what like a fe but not identical they are still way cool engines just look for a earlier built engine they had the most power
Old 02-23-2005, 08:01 PM
puggies v8's Avatar
puggies v8
puggies v8 is offline
I would go with a 557, stroked 460, call Keith Craft Racing Engines! This will put the WOW on them!
Old 02-23-2005, 10:19 PM
Ogrebonz's Avatar
Ogrebonz
Ogrebonz is offline
It'll put the WOW on my wallet too. Anybody got a dimensional drawing of a 534? Ogre.
Old 02-23-2005, 11:10 PM
glennbin's Avatar
glennbin
glennbin is offline
spec sheet
Ogre
I can't post any attachments on this site and am new user so I can't use links.
Any ideas on howto get you a copy of the instlation spec sheet.If nothing else works try calling me at 604-961-6070
Old 02-23-2005, 11:32 PM
rusty70f100
I'm interested in seeing this too, so go make some posts in the test forum to get your post count up, then post the link.
Old 02-23-2005, 11:39 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,591 Likes on 1,296 Posts
Scroll down to "vital statistics" for dimensions.
https://www.ford-trucks.com/forums/s...d.php?t=220095
Quick Reply: Just how big IS a 534?
