1983 - 2012 Ranger & B-Series All Ford Ranger and Mazda B-Series models
Evaporative Emission Control System Leak
Old 02-10-2005, 12:31 PM
byo71's Avatar
byo71
byo71 is offline
check engine light came on on '01 3.0L Ranger. Pulled code PO456 (i think) "Evaporative Emission Control System Leak (small leak)"
What could cause this.
I've been trying to search for a couple of houre but I always get a message saying the system is under high load.
Old 02-10-2005, 12:58 PM
stackclimber's Avatar
stackclimber
stackclimber is offline
I had a simular problem on a B2300 and it turned out to be the fuel vapor recovery system. There is a solenoid that holds pressure in the fuel tank and mine had gone bad. It my be your gas cap too. Just a thought
Old 02-10-2005, 01:00 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
P0456 P0442 EVAP Control System Leak
P0456 - EVAP Control System Leak Detected (Very Small Leak)
The PCM monitors the complete EVAP control system for the presence of a very small fuel vapor leak. The system failure occurs when a fuel vapor leak from an opening as small as 0.508 mm (0.020 inch) is detected by the EVAP running loss monitor test. Possible causes are:
- Very small holes or cuts in fuel vapor hoses/tubes.
- Loose fuel vapor hose/tube connections to EVAP system components.
- EVAP system component seals leaking (refer to Possible Causes under DTC P0442).
P0442 - EVAP Control System Leak Detected (Small Leak) possible causes:
- After-market EVAP hardware (such as fuel filler cap) non-conforming to required specifications
- Small holes or cuts in fuel vapor hoses/tubes
- Canister vent solenoid stays partially open on closed command
- Damaged, cross-threaded or loosely installed fuel filler cap
- EVAP system component seals leaking (EVAP canister purge valve, fuel tank pressure sensor, canister vent solenoid (see post immediatly above), fuel vapor control valve tube assembly or fuel vapor vent valve assembly)
Old 02-10-2005, 02:26 PM
byo71's Avatar
byo71
byo71 is offline
Thanks for quick responses!
Rockledge, where do you find those descriptions for the codes??
Old 02-10-2005, 08:15 PM
Rockledge's Avatar
Rockledge
Most OBD-II trouble code descriptions can be found here:
Look up 1995+ Ford OBD-II Diagnostic Trouble Codes (PDF)
But I had to go to my Ford Factory Manual to look up DTC P0456 since it was not set forth in the above-referenced PDF file.
The Factory Repair Manuals can be found at Helminc.com or you can check out eBay.
Old 02-04-2011, 03:35 PM
pablocruz69's Avatar
pablocruz69
pablocruz69 is offline
Where is the are these part located in the engine compartment (solenoid, fuel vapor hoses etc.) I have a friend that has an 03 ranger that we pulled the same code with my scanner. I saw that the evap solenoid was located near the brake line block. Just trying to help a friend out. BYO71 what was the final diagnosis of your issue? Thanks in advance for any help that you may be able to give.
Old 02-04-2011, 03:40 PM
byo71's Avatar
byo71
byo71 is offline
I wish I could tell you. this was a few years ago and the truck is long ago sold. I cant even remember if I ever fixed it. Sorry.
rangersvt04
3.0L V6
52
03-02-2022 12:41 PM
mkotalik
1997 - 2003 F150
09-26-2016 11:42 AM
bcoogs
1997 - 2003 F150
07-27-2009 05:46 PM
fishon2
07-08-2009 07:08 AM
rangersvt04
09-16-2003 07:36 PM
Quick Reply: Evaporative Emission Control System Leak
