Iowa Chapter Join Chapter, Leader:
A cold, straight ride
Old 02-09-2005, 08:22 AM
69 and 85's Avatar
69 and 85
69 and 85 is offline
Drove my truck for the first time in about a month today. She started right up and all seemed normal. Got a mile down the road and found out my turn signals aren't working. Then I flipped on the blower as my temp guage said the well anticipated heat was ready - blower is dead.
I just got to work and haven't looked into it yet.... I imagine one of the flashers is bad. Guess I will be cheking fuses, etc tonight ( if I don't freeze on the way home!)
Old 02-09-2005, 11:52 AM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
that stinks in this weather I have the same problem with the little ranger no turn signals I can only go straight, guess thats better than a stuck signal where you go in circles all the time. my problem with my heater is the truck sat for like 2 yrs, adn has moisture in the ducts somewhere, so when I turn the defrost on it fogs the windows.
Old 02-09-2005, 12:15 PM
Sam_Fear's Avatar
Sam_Fear
Sam_Fear is offline
Sounds like a pinhole leak in the heater core. But then I used to have a vehicle (Datson 310?) that would blow snow inside the defroster from the cowl! Crappiest vehicle I ever owned. Hmmmm...
Old 02-09-2005, 12:20 PM
monsterbaby
nope not a hole in the heater core 2 reasons I know this one if it is antifreeze you can smell it, second no loss of coolant or wet in cab, it has a fabricated air box to clear the 302, and I figure that in the 2 years of sitting a mouse nest was built in there and got wet, and this is the moisture from that when I get it warmed up. (only does it when it is completely warmed up, and putting out hot air)
Old 02-10-2005, 09:17 AM
69 and 85's Avatar
69 and 85
Musta been gremlins... anyway, they left for now. When I left work yesterday the heat was good and the turn signals worked. I guess she justed needed a day in the sun. Go figure.
Old 02-10-2005, 04:20 PM
truckertaz's Avatar
truckertaz
truckertaz is offline
Sometimes some of them old things just need a good swift kick in the tires and a few cuss words to wake them up
Old 02-12-2005, 05:16 AM
wyldstallyn73's Avatar
wyldstallyn73
wyldstallyn73 is offline
My guess is its your ignition switch has play in it and needs to be in just the right spot to make contact with everything.
Old 02-12-2005, 12:05 PM
monsterbaby
I just had another thought along those lines, I had one that was just old and gummy, and when it got cold the grease was just stickly enough that it wouldn't come all the way back to the run position on its own, but just a slight amount of preasure would bring it into position and away you go.
Good call stallyn don't know why I didn't remember that one.
Old 02-13-2005, 11:48 PM
69 and 85's Avatar
69 and 85
Hey thanks guys... makes sense. If it happens again, I'l give it a lil pressure. These really are great ol' trucks.... but it doesn't hurt to learn sometricks along the way!
Thanks again!
