Minnesota Chapter Join Chapter, Leader: fordpower88
Anyone have 38's for sale?
Old 02-07-2005, 10:28 AM
lowboy250's Avatar
lowboy250
lowboy250 is offline
I just put a lift on my truck and am looking for 38's. I want them to be for a 15 or 16 inch rim, preferrably 16 inch. Thanks.
Old 02-07-2005, 12:29 PM
Boss_358's Avatar
Boss_358
Boss_358 is offline
You should try some of the 4x4 shops and see if they have anything that someone didn't want or exchanged. Otherwise the only used one I think your going to find wont have much tread left. Good luck. Oh yeah, you would more than likely be better with a 16 inch rim. More wheel to support the tire means less sidewall flex. When I get my 78 done I found that they make 37 inch BFG All Terrains for a 17 inch wheel. That should work perfect in my case.
Old 02-07-2005, 07:22 PM
darkknight9's Avatar
darkknight9
darkknight9 is offline
Signs that you need to spend more time on truck web sites and truck talk than on firearm related forums:
When you spot a subject and you assume the poster is inquiring about .38 pistols.
Old 02-10-2005, 11:23 PM
Boss_358's Avatar
Boss_358
Boss_358 is offline
The trident logo probably doesn't help.
