I need info on my 534
Old 01-27-2005, 07:49 PM
Maximman's Avatar
Maximman
Maximman is offline
Question I need info on my 534
How many quarts does a 1962 534 engine take ?
What weight of oil should I use ?
Does anyone know what Autolite sparkplug is recommended for this engine ?
Old 01-29-2005, 10:09 PM
Birken Vogt's Avatar
Birken Vogt
Birken Vogt is offline
I don't remember how much, but you won't go wrong with good ole SAE 30, it's what was expected when the motor was new. 10W-30 probably would not hurt it either if it is cold where you are, or 15W-40 like the diesels use. It's not a high tech machine.
You should be able to find the spark plugs listed in an auto parts store still.
Birken
Old 02-11-2005, 01:09 AM
FiX-ZiT's Avatar
FiX-ZiT
FiX-ZiT is offline
birken-
The 534-477-401 takes autolight #124- with a .040 gap. I just installede a set in my F850 super duty this A.M.
FiX-ZiT-
Old 02-16-2005, 02:12 PM
glennbin's Avatar
glennbin
glennbin is offline
A 534 takes 11 quarts dry 9 to refill and in my book it states
sae 40 +90 degree's and above
sae30 or 20w-40 +32 -90 degree's f
sae20w or 10w30 -10-32 degree's f
sae10w 5w-30 below 0 degree's f
spark plug type turbo action, 18mm
Old 02-16-2005, 05:16 PM
Maximman's Avatar
Maximman
Maximman is offline
What type of book do you have? I'm just wondering. Thanks for the info.....Bob
Old 02-16-2005, 06:06 PM
glennbin's Avatar
glennbin
glennbin is offline
I have the original owner's and operator's manual.
models Q-401
M-477
N-534
6t56
401, 477, & 534 SD Engines
06-09-2020 03:31 PM
deere81
02-05-2018 08:49 AM
Jim534
09-01-2017 07:16 PM
62FE4x4
Large Truck
06-30-2016 02:02 PM
beegeezy
29
10-05-2006 08:13 PM
Quick Reply: I need info on my 534
