Need info on my 534 v8
Old 01-27-2005, 05:41 PM
Maximman's Avatar
Maximman
Maximman is offline
I have a 1962 534 engine in a fire truck. I need to know how many quarts of oil would this engine take and what weight oil ?
What number of Autolite spark plug does it take ?
Old 01-28-2005, 01:11 AM
camperspecial65's Avatar
camperspecial65
camperspecial65 is offline
by my book, the plug is a BTF-31, gap of .028 to .032 for normal and severe use only it says...
capacity is 11 quarts w/new filter according to my shop manual(65) but pan is same for all yrs, so should be the same
Hope this helps that bad boy cs65
Old 01-28-2005, 07:37 PM
pottymouth2's Avatar
pottymouth2
pottymouth2 is offline
I don't know about the climate where you are, but in the "Southern" states 10W40 motor oil is sufficient year 'round. Check the owners manual in most vehicles for an ambient temperature versus oil weight chart.
Old 01-29-2005, 01:41 AM
nealjpage's Avatar
nealjpage
nealjpage is offline
If it's a good engine without too many leaks or doesn't burn much, I recommend 5-30. It's thinner at startup so the oil gets to circulating quicker. Otherwise, 10-30 is the old standby.
ac7880
24
12-01-2021 09:20 PM
cfd590
401, 477, & 534 SD Engines
02-23-2016 05:32 PM
SuperBerry111
11-03-2013 09:30 PM
mt534
04-29-2010 11:36 PM
grumpy1
01-31-2006 04:04 AM
Quick Reply: Need info on my 534 v8
