Mercon SP Tranny Fluid
Old 01-26-2005, 10:02 AM
psmith338's Avatar
psmith338
psmith338 is offline
It's time to service my tranny. I found a great deal on filters at Filter1, but I can't find the fluid anywhere but the Ford dealer & they want $4.62 a quart!
Any suggestions?
Old 01-26-2005, 11:55 AM
rstokes's Avatar
rstokes
rstokes is offline
It's called GOTCHA! Swallow hard and go ahead and pay the FMC dealer's price because that's the only place to my knowledge (and I've checked it out fairly well) that you can buy the SP and any other fluid will ruin your transmission or at the least void your warranty, if discovered. Sorry, there's no shortcut on this one.
Old 01-26-2005, 04:19 PM
tn mac's Avatar
tn mac
tn mac is offline
also there is no way to drain the fluid out of youe torque converter except the flush and drain system the dealer or trans shop has,without getting all the fluid out it kinda a waste.
Old 01-26-2005, 05:56 PM
fyrhog's Avatar
fyrhog
fyrhog is offline
Mercon
I wonder where the trany shops get Mercon?
Old 01-26-2005, 10:12 PM
keith58's Avatar
keith58
keith58 is offline
fmc.
aftermarket shops buy from the direct maufactureres all the time
Old 01-26-2005, 10:26 PM
bdjupiter's Avatar
bdjupiter
bdjupiter is offline
Look up at the tech articles at the top of the page, then go to transmission and read up. I did what was indicated and changed mine this summer. It was easy and let the wife feel like she was helping by starting the truck and turning it off. I used Mobil synthetic and the truck runs and shifts like a champ and I won't have to do it again for quite a while!
Old 01-27-2005, 07:25 AM
SBV45's Avatar
SBV45
SBV45 is offline
In Central Texas I found Mercon SP at a local parts house that is owned by Arnold Oil company, a local distributor.
The 30k maintenance only calls for a drain and fill and external tranny filter change. The flush is extra and not necessary. I did the drain and fill. It took 8.25 quarts. I know a local trans shop that won't do the flush.
Old 01-27-2005, 01:27 PM
turbohatch's Avatar
turbohatch
turbohatch is offline
I know Valvoline has Mercon V SP in synthetic blend.I don't know the price but I hope this helps.
Old 01-27-2005, 02:02 PM
Casey's Avatar
Casey
Casey is offline
MERCON V is different from MERCON SP. You can't use MERCON V in a TorqShift without causing problems.
Old 01-27-2005, 02:18 PM
SBV45's Avatar
SBV45
SBV45 is offline
Casey is right on. Read your owner manuals.
Some transmission fluids may be labeled as dual usage, such as
MERCON and MERCON V. These dual usage fluids are not to be used
in an automatic transmission that requires use of the MERCON type
fluid. However, these dual usage fluids may be used in transmissions that
require the MERCON V type fluid.
MERCON, MERCON V and MERCON SP are not
interchangeable. DO NOT mix MERCON, MERCON V and
MERCON SP. Use of dual usage fluids in an automatic
transmission application requiring MERCON SP may cause
transmission damage. Use of a transmission fluid other than the
recommended fluid may cause transmission damage.
Old 01-27-2005, 07:34 PM
tn mac's Avatar
tn mac
tn mac is offline
SBV45
If you dont do the flush how do you get the fluid out of the converter,there is no plug,seems kinda like changing your oil and not the filter to me.
Old 01-28-2005, 07:39 AM
Casey's Avatar
Casey
Casey is offline
There are two ways to get the oil out of the torque converter. One is the flush method, and the other is to take the torque converter out of the transmission and drain it.
I use the flush method. Pulling the trans each time I need to change the oil is too much work!
Old 01-28-2005, 10:15 AM
SBV45's Avatar
SBV45
SBV45 is offline
tn mac,
You are right, the new fluid mixes with the old. Drain and fill is a recommended procedure. Both drain and fill and flush are shown in the service manual. There is no recommendation or cautions on mixing the trans fluid or concerns on not draining the torque converter.
I looked at the fluid on the dipstick prior to changing. It was still red and clear. I spoke to the manager of a transmission shop that I know and trust. His shop doesn't do flushes. He said on a new trans, he would be okay with doing a flush, but it isn't necessary. Just don't go any longer than the recommended maintenance period.
As for comparing the trans drain and fill with changing oil without changing the filter, you don't have the internal combustion process going on in your tranny. I got your idea, just not the same.
Old 01-28-2005, 03:12 PM
tn mac's Avatar
tn mac
tn mac is offline
I agree not quite the same but it gets the fluid pretty hot, and it also gets dirty, guess this is one of those times we agree to disagree. would that be a another time warp thing, ha ha.
Old 01-28-2005, 05:21 PM
kb1aah's Avatar
kb1aah
kb1aah is offline
Question Transfer Case?
So what about changing fluid on the transfer case? I don't beleive it shares the fluid with the trans like some vehicles. What is the schedule for this? What type of fluid does it use?
Quick Reply: Mercon SP Tranny Fluid
