Thawing frozen fuel line
My '95 Aerostar insists on freezing up whenever the temperature drops too low. Forgot to put gas line antifreeze in on the last fill and now it is sitting in my driveway - too steep to push it in the garage to warm it up...Any thoughts on how I can warm it up enough to start it while outside in my driveway? Gonna be about -15C again tonight...
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick
around someone will be by shortly...to answer your question.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
Enjoy FTE …..
Hot Air Pop Corn Popper
This sounds like a perfect application for that old Hot Air Pop Corn Popper you have laying around the house. (They can be had at Goodwill for about $2.00). Slide it under the vehicle and plug it in. I have one as an auxillary heater in my van for those cold winter camping trips. It really pours out the heat!
dancre
if you have like a nipco heater that runs on fuel or propane and it blows you can put a run of stove pipe and a elbow point it under the van and let it blow under it kinda toward the engine compartment keep a good eye on it so things dont get to hot.That is the fastest way I know how.
If you have one of those hot mist steemers it would work spraying the hot mist along the fuel line.
A hair dryer would work also just be a careful to keep any water drops away from the inner heating elements or you'll have an instant Afro same to say with popcorn poppers keep all water away from the air outlet since I assume the underbody of the vehicle probably has some ice on it too.
Truckin' Travis
09-26-2012 10:29 PM
gmcman101
1983 - 2012 Ranger & B-Series
05-29-2012 03:43 PM
Big Dave
Oil & Lubrication
06-19-2004 10:37 PM
