Windshield washer switch removal
Old 07-30-2002, 09:07 AM
mfross's Avatar
mfross
mfross is offline
Hi All:
Just bought a 1986 Ford F-150 for me and the son to work on. Bit of a project vehicle.
First things first, is there some special tool or technique for removing the windshield washer switch without taking the whole dash off? Mine is bad (it keeps going after you turn it off) and obviously needs to be replaced.
Thanks,
Joe Collins
Old 07-30-2002, 11:41 AM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Whole Dash?
Is Un-necessary
Disconnect battery.
After you take the headlight switch with slider/**** out and remove the wiper switch ****.
Remove the instrument cluster bezel.
Remove the wiper switch
Replace wiper switch
Replace Bezel
Replace headlight switch slider /****
Replace wiper switch ****.
http://www.clubfte.com/users/mil1ion/2cents.gif
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old 07-30-2002, 08:55 PM
Agent86's Avatar
Agent86
Agent86 is offline
[updated:LAST EDITED ON 30-Jul-02 AT 09:57 PM (EST)]*Made this a new post*
Old 08-01-2002, 08:08 AM
mfross's Avatar
mfross
mfross is offline
Thanks for your help!
Joe Collins
Old 08-01-2002, 01:13 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,675 Likes on 1,354 Posts
Make a hooked tool to depress the catch on the wiper **** to release it from the switch shaft. Also, I would try the switch first, but there is a chance it could be the wiper motor. It has a cam switch built into the motor, and there is a hot wire going to the motor at all times. This feature lets you kill power to the wipers with the dash switch, with the wipers in any position, and they will follow through their stroke until they get to the "park" position. If something fouls the cam switch in the motor, they could possibly run all the time.
Old 08-04-2002, 04:18 PM
brokebronco's Avatar
brokebronco
brokebronco is offline
That and it also could be the interval govenor(black bow wired between the switch and the wiring harness) which is mounted near the switch under the dash.
BROKEBRONCO
Old 08-06-2002, 03:31 PM
mfross's Avatar
mfross
mfross is offline
This is the problem--even though the switch is in the off position, it still cycles about once every couple of minutes. It isn't the switch nor the motor, what is it?
Thanks,
Joe Collins
Old 08-06-2002, 06:38 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Wiper Relay?
[/font]
[/font]
Old 08-06-2002, 09:26 PM
mfross's Avatar
mfross
mfross is offline
The wiper relay looks like what and where is it hidden?
Thanks very much!
Joe Collins
Old 08-07-2002, 03:22 PM
mfross's Avatar
mfross
mfross is offline
Found the governor, now what? Could it be causing my windshield wipers to cycle once every couple of minutes or is it something else? The windshield wipers seem to work otherwise.
Thanks,
Joe Collins
Old 08-07-2002, 03:26 PM
brokebronco
To narrow it down some;
Unplug the govenor from the circuit completely. plug the switch into the wiring harness. If your problem goes away you have some sort of internal short in the govenor. As I said earlier if the interval is no big deal it wiil be alot cheaper to get a switch for the 2 speed wipers.(hi/low)
BROKEBRONCO
84 Bronco 351HO/C-6/208/10.25 Rear/D44TTB Soon to have D60 Front/NP435
86 F250 351HO/C6/10.25 Soon to have a front axle and the ZF tranny
Old 08-08-2002, 01:05 AM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
I assume you have twisted the switch **** each direction to see if all the functions work?
[/font]
[/font]
Old 08-11-2002, 10:06 AM
mfross's Avatar
mfross
mfross is offline
Took the controller out and plugged in a 2 speed switch and everything seems to work for now. I'll be looking for another controller though...
Thanks for your help,
Joe Collins
Old 08-11-2002, 10:08 AM
mfross's Avatar
mfross
mfross is offline
All of the functions work both ways except that the silly thing cycles on its own once every minute or so. Any ideas?
I have a 2 speed switch in there now and it seems to work fine and it'll have to do until I can find another controller to swap it out with.
Thanks,
Joe Collins
Old 08-11-2002, 01:45 PM
Franklin2's Avatar
Franklin2
asphaltburner
Colorado Chapter
20
03-27-2015 05:29 PM
Monana ford Man
01-09-2012 07:33 PM
pdqford
04-01-2008 11:19 AM
Russ8393
1983 - 2012 Ranger & B-Series
04-06-2007 08:54 AM
BIG Black Beauty
1997 - 2003 F150
02-10-2003 04:41 PM
Quick Reply: Windshield washer switch removal
