installing new glow plugs
First off, yes it does make a difference. I have run across many folks who have had problems with the Autolite glow plugs either swelling over time so you cannot get them out if replacement comes up (a pain but not a catastrophe) or breaking off inside the engine with the expected major internal damage. I would take them back and get the factory units. If you have AutoZone in your area they sell the Motorcraft (made by Beru) in Motorcraft part bags with the Ford part number on them for under $10 each. Their part number is ZD-11.
As for the installation, CLICK HERE to go to an excellent how to article on the glow plug system by Carpentractor.
Hope these help out - Carpentractor's article helped me a lot.
Do NOT use the autolite glow plugs! I had four break off while removing. I spent hours removing three of of the broken ones from the top side. The fourth one broke and left the element in the head. Two dealers said the head would have to be removed. Instead i was able to remove it through the fuel injector hole. I dont ever want to do that job again. Please use the motorcraft glow plugs!!!!!!!!
Anti sieze has nothing to do with it, it's not the threads on the head that are the problem it's the element itself as it swells up with repeated heating then when you try, and pull it out it doesn't fit through the hole, and breaks off leaving the tip sitting on top of the piston you might as well drop gravel into your intake (they will also just burn off and drop down also or so I have heard)
Originally Posted by mikeAK
I was wondering if I could still use the autolite 1111 glow plugs if I used some sort of anti-sieze stuff?
So if I do use the motorcraft plugs, has anyone had trouble with them.
regards
regards
As for Motorcraft, I have not had a problem with mine and I have not run across anyone else who has in four and a half years on 9+ forums that deal with diesels, Fords, towing and the like.
You can do as you wish.
Dave / Believer45
I have the same problem with 3 glow plugs on my '97 F250 Powerstroke (206,000 miles). My mechanic is ready to remove both cylinder heads tomorrow due to siezed glow plug electrodes. He has tried (for several days) penetrating oil with no results. I am concerned at this point about debris from the electrode being left inside. Is it best to remove the heads now or should we keep on trying the penetrating oil method? If the heads are removed, what gotcha's are there that we should look for? How mush should head removal cost on a powerstroke?
Any advice would be appreciated.
Thanks,
rus7755
Thanks,
rus7755
Welcome Mark, to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly...to answer your question.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
Enjoy FTE …..
Y2KW57
59
01-29-2017 01:44 PM
