Will 3/4 ton 4X4 front axle......
Old 09-11-2002, 05:40 AM
larryswelding's Avatar
larryswelding
larryswelding is offline
Post Will 3/4 ton 4X4 front axle......
Does anyone know if a 3/4 4X4 front axle will fit into a 1 ton 2WD (F-350)truck ?? Thanks
Old 09-11-2002, 06:59 AM
cdd5599's Avatar
cdd5599
cdd5599 is offline
I am not sure if the axle will fit. But the problem is you have to run the same gears in the front and rear. Your 1 ton axle is more thank likely a different ratio.
Chuck
Old 09-11-2002, 08:26 AM
DannyP's Avatar
DannyP
DannyP is offline
It depends on what year the donor vehicle is and what year the recipient vehicle is. Can you be more specific?
DannyP
Old 09-11-2002, 09:41 PM
otto's Avatar
otto
otto is offline
not without major modifcations including lotsa custom fab work and lotsa donor parts, cobbling add as needed
Old 09-12-2002, 03:23 AM
larryswelding
The 1 ton is a '85, but I believe for a few years prior & a few years post they were the same, no ??
Old 09-12-2002, 05:47 AM
DannyP's Avatar
DannyP
DannyP is offline
Does the 3/4 ton donor have a solid front axle or an IFS? The 3/4 and 1 ton frames of like years are pretty much the same I think including the bolt holes for locating various suspension components. You need to crawl up under both vehicles with a tape measure and start measuring.
DannyP
Old 09-12-2002, 05:44 PM
otto's Avatar
otto
otto is offline
3/4 ton front axles is twin traction leaf sprung, 85 f-350 has twin ibeam and should be coil sprung
Old 09-12-2002, 07:48 PM
FoMoCo69's Avatar
FoMoCo69
FoMoCo69 is offline
LarryP2
20
08-14-2012 09:28 AM
sharky
10-04-2011 06:45 AM
460
Offroad & 4x4
11-17-2006 07:25 PM
EricJ
10-28-2005 01:43 PM
chris_2
10-18-1999 09:46 PM
Quick Reply: Will 3/4 ton 4X4 front axle......
