can you temporarily patch a fuel line?
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly...to answer your question.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
Enjoy FTE …..
I don't know about high pressure FI lines, but it works OK with low pressure fuel lines. The line had rubbed against a clamp and worn through, so I got a chunk of fuel hose, split it lengthwise, and hose-clamped it over the leak. It held.
Or you could cut out the bad section, flare the cut ends, and splice in a replacement line using couplings. If that works for brake line, it ought to be good enough for high-pressure fuel lines too.
351Cleveland C4
20
08-12-2015 02:49 PM
