Chapter Leader Forum???
LOL!! This is funny. I got my permissions all worked out and now you guys can't see it.
I'm sure it will all be worked out soon enough. Be patient, my friends. Just say it's all Dicks fault and go grab yer little voo doo dolls of him and a handfull of pins and then ........ what the HECK am I saying!!!!
Originally Posted by fordborn
I no longer can see it either. Also received an email saying there was a reply in the forum and when I click on it I am told that I do not have the proper rights to see it.
I just checked the permissions and they were OK. This seems to be a different problem than the Mod's access to the CL forum. Heavnbound's account shows the same signs of corruption that are shown in three moderator's accounts that can't see the mod forum. I will check some files:
Other corrupt files:
f=2504by497
mustange70
fordborn
-All three of you so far.
The consistent sign of corruption I have seen is that the following item has no Y/N setting in the file:
"Pop up a Notification Box When a Private Message is Received"
Just for grins... Can you guys check your User CP and see if a setting for that option shows? Then see if you can set it. After you have set it, test your access to the CL forum. When I have set the option in the past from the Admin panel it has made no difference. Let me know what you find out.
f=2504by497
mustange70
fordborn
Thanks guys!
Both accounts now show that option checked in the Admin panel. When I set the option on other accounts thru the Admin panel it did not help either but I could always hope...
Sorry it did not help. It does show as a the only consistent indicator or abnormality that I have found for Ken. Unfortunately there is another bug in the software from a recent security patch that may be causing more damage than it is preventing. It all may be related. I am kind of dead in the water for permissions upgrades, new mods, etc until this is solved. I don't want to be messing up files any more than they are.
One interesting side note, Fordlover1951's file shows the same missing setting but he is able to access the mod forum. So the corruption indicator is not 100%. I can't remember if it was set the last time I looked at it because I check soooo many of those things everyday...
Maybe you guys can get together and see if you can remember the last time you changed anything in your User CP. Maybe you all recently accessed some feature????? -Grabbing at straws.
