Virginia Chapter Join Chapter, Leader:
My truck is tryin to Kill Me
Old 01-07-2005, 05:50 PM
MonsterBroncoKid's Avatar
MonsterBroncoKid
MonsterBroncoKid is offline
okay so im drivin down the road one day and i had to swirve suddenly to avoid being t-boned by a big rig. no biggie, but when i did it my battery fell over on the motor during this process the truck just started shaking violently back and fourth and flung the top of my bronco off of the truck. now ive strapped the battery down and no more battery problems, but for some reason now the truck at random will violently shake as before even though the the battery isnt on the motor. now ive check the balljoints and all steering linkage shocks and such and evrything is fine.
does anyone know what or have an idea what the hell is causing this? i needf to kinow before the truck kills me!!!!!!!!
Old 01-10-2005, 09:55 PM
Franken-Truck's Avatar
Franken-Truck
Franken-Truck is offline
Did any battery juice get on anything? Did the battery short out on the motor? Are you sure its not the motor missing badly? Where did the battery hit?
Old 01-16-2005, 07:00 PM
MonsterBroncoKid
Unhappy
nope no battery juice on anything, yes it did short out a lil bit, it landed on the altenator and stalled the belts briefly, and yes the motor was, but no longer is out of time or missing.
Old 01-16-2005, 09:18 PM
Franken-Truck
I don't know, this is a weird problem. If the there was a short on the motor, I would check for loose or burned wiring, melted connections, maybe even have the computer system checked for any shorts. I betcha a nickel that your problem is electrical. My cousin had me drive her car to see what was causing it to jump really bad. I told her it might be the clutch going. It felt like it would slip, then grab, it was that violent. Turned out to be a fuel delivery issue, some shorted out relays.
Old 02-14-2005, 06:20 PM
73-79owner's Avatar
73-79owner
73-79owner is offline
bad shake
my dads truck did the shake thing real bad, it was his bushings on the radius arms that were worn out. Replaced them and never did it again.
Old 02-15-2005, 05:22 PM
MonsterBroncoKid
thanks man i appreciate it but i already got rid of the truck and that wasnt the problem though. refer to the post Tragedy strikes
jaltman1984
01-04-2015 12:15 PM
79sparky
16
01-15-2012 08:52 PM
badboyina67
13
04-02-2011 04:55 AM
mxhowes1
06-24-2008 12:18 PM
Quick Reply: My truck is tryin to Kill Me
