REPLACING BALL JOINTs ON F150 2000 MODEL
Old 01-04-2005, 10:28 PM
FASTSHIPPER4U's Avatar
FASTSHIPPER4U
FASTSHIPPER4U is offline
I just had my oil changed and the shop said I need to have my upper ball joints replaced, (truck is make clicking noise when making sharp turns) I was thinking of doing it myself, Is the any tricks or special tools needed, I know I will also have to have the front end alined, should I go ahead and replace the lower ball joints while im at it, and if so are that hard to replace, thanks for any help.
Old 01-05-2005, 07:18 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Enjoy FTE
We are happy to have you on board!~
Old 01-05-2005, 09:21 AM
BillyBob69's Avatar
BillyBob69
BillyBob69 is offline
I haven't done it myself but I have seen a whole lot of threads in here covering that. Do a search on "Balljoints" in this forum. I am sure you will find what you are looking for.
WELCOME!
Old 01-05-2005, 04:23 PM
TEEJAY's Avatar
TEEJAY
TEEJAY is offline
Hello,
Upper balljoints are much much easier than lowers. Upper replacement ball joints come already pressed into new A-arms. No special tools required. Just mark the cams (look like big washers) on the bolts that hold the control arms, it will make the alignment easier.
Lower balljoints usually wear out first so make sure you only need the upper ones. If you don't need lowers, don't look for trouble as you can expect to replace the brake pads and rotors from having to beat them off and also you will need a good hammer and usually a balljoint press. You will also need a hub socket (I think 33m) to remove the spindle and will need to carefully seperate the tie rods. I just did them this weekend on my truck (second time in 3 years) so everything is fresh in my mind.
Old 01-06-2005, 02:26 PM
FASTSHIPPER4U
I ended up replacing the upper myself this yesterday, I ran in to one problem, in order to get the aliment right you have to replace the bolts that hold the arm on and also replace the ford factory washer with a cam washer, the nut/bolt and washer kit was 20.00 a side, but no one told me that at the parts house so I ended up redoing it all today, Good luck
Old 01-06-2005, 09:27 PM
TEEJAY's Avatar
TEEJAY
TEEJAY is offline
When I did the upper ball joints I re-used the same bolts and cams. No one at the alignment shop ever told me any different and there seemed to be no problem with alignment. Did something happen to yours that they had to be changed?
Old 01-06-2005, 09:53 PM
FASTSHIPPER4U
Nothing was wrong with my original screw and etc, In fact I called a few other shops and they said you have to change them in order to aline if proper, I would just keep an eye on the front tires for more than regular wear,
Old 01-06-2005, 10:03 PM
TEEJAY's Avatar
TEEJAY
TEEJAY is offline
The first time I did mine I did them with a guy who owns a front end shop and he never mentioned to me that I needed new ones. That was about a year and a half ago and no problems since. I'll have to watch for any problems, but I remember him telling me to mark the old cams so I could re-install them close to their original location.
Old 01-07-2005, 05:47 PM
bridomine99's Avatar
bridomine99
bridomine99 is offline
The guys may make it sound easier than it is
My roomate and I did his on a 97 f150 and it was no simple task. We are far from mechanics, but this was a 2 nighter for us.
Old 01-09-2005, 08:21 AM
GORDYSBRONCO's Avatar
GORDYSBRONCO
GORDYSBRONCO is offline
Change Lowers As Long As Its Apart ,if Its 4x4 Auto Zone Will Lend You The 36mm I Think That Was It Socket Needed For The Axel They Will Also Lend You A Ball Joint Press Needed For The Lowers. I Saved $300 Doing My Lowers Myself
Old 01-09-2005, 08:25 AM
GORDYSBRONCO
Also Better Look At Tie Rods Ends Mine Broke Change Them (all 4)
Long Your At It BUY THE WAY THAT WAS ON MY 2000 F-150 4X4 SC
Old 01-09-2005, 02:41 PM
TEEJAY's Avatar
TEEJAY
TEEJAY is offline
I disagree, the lowers are much more difficult and time consuming than the uppers. The uppers can be done in about 15 minutes while the lowers could take 2 or 3 hours with special tools. Since the lowers usually go first, the uppers are usually done at a different time some why do extra work if you don't need to?
tom1243
1999 to 2016 Super Duty
01-16-2017 06:34 PM
colin1966
15
10-23-2016 08:36 PM
cookie88
09-15-2012 01:14 PM
My96Bronco
1978 - 1996 Big Bronco
08-08-2006 10:25 PM
69crewcab
06-19-2003 11:42 PM
Quick Reply: REPLACING BALL JOINTs ON F150 2000 MODEL
