What max. p.s.i. does a typical Ford power steering pump create?
I'm interested in how many psi a Ford powersteering pump can create, at what rpm, and approx. how much power the pump draws. Also, do the pumps have built-in relief valves or are the relief valves in the steering box? I have a few projects in mind that could utilize hydraulic power and I am curious what these power steering pumps are capable of. Thanks, Jake
I would recommend against using the Ford pump. These things have an integral reserve, and if you are running a ram of any kind, it will drain this quickly. Also, they do not like being run low on fluid. I would use a pump from a japanese truck, as they use a remote reserve, and you can make it any size you want. They also produce more pressure at a lower rpm. I am rigging one off of my old Isuzu Trooper diesel to fit my 84 F-250, to power a hydraulic winch. Northern tool and equipment also has a wide variety of hydraulic pumps for different app's.
Jared
Jared
The Ford CII pump (F150-350, Bronco) flows 1.5 gallons/minute at 740 psi. The pressure relief is in the pump and set at 1400 to 1500 psi.
The Ford Saginaw pump (E100-350) flows 1.8 gallons/minute at 620 psi and its relief valve is set at 1350 to 1450 psi.
Ben_E
06-30-2017 11:53 PM
KYSlowhand
11-25-2016 07:39 AM
Justins68ford
07-23-2011 06:36 PM
