power distribution box diagram
Old 12-29-2004, 10:29 PM
Jason77090's Avatar
Jason77090
Jason77090 is offline
i recently battled the door ajar problem, and won the battle, but lost the war. I went to remove fuses to eliminate the light, and now the truck is acting like it isnt gettin gas. I would like to see if someone could find the diagram and possibly what fuses need to go where in that box.. any help would be appreciated
Jason
97 4.6 L
Old 12-29-2004, 10:40 PM
hugger94's Avatar
hugger94
hugger94 is offline
Just a question out of the blue... Does the door ajar problem appear after a rain or heavy dew/fog? If so you might want to have the window checked for leaks. Mine started out with the door ajar, then progressed to 4x4 indicator flashing and alternating with the overdrive light on the end of the gear shift lever.
Just asking it you notice this problem appearing after a rain but eventually clears itself up when the rain stops and has a chance to dry out.
hugger94
97 F150 5.4L 4x4
Old 12-30-2004, 06:46 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
Jason
97 4.6 L
Welcome to the only family Ford Truck site, on the net. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you on board!~
Old 12-30-2004, 11:28 AM
Jason77090's Avatar
Jason77090
where would i go to locate that.. sorry, im new to this forum
Old 12-30-2004, 07:44 PM
Dealford's Avatar
Dealford
Dealford is offline
Welcome to FTE!
Near the top of every page you'll see in the dark blue ribbon "User CP". "FAQ", etc., etc. Click on FAQ then pick a topic & click on that. Most everything is explained there.
Also, click on "User CP" & you can update your signature, etc., etc.
As you look around this site, click on everything because this site is just loaded with features & you'll be amazed at the extra info you'll find "hidden" throughout.
AL.
Old 12-30-2004, 08:32 PM
Jason77090's Avatar
Jason77090
just an update.... i switched the fuel pump relay with one that i know works.. and it still wont fire, and i replaced the fuse in the box with a new one. and it STILL wont fire... any help would be greatly appreciated
Jason
arkiados
11-29-2022 08:31 AM
danyl01967
07-25-2011 08:28 PM
jls8177
03-12-2010 04:34 PM
RCrawler
02-06-2010 10:02 AM
lobsterboy
Electrical Systems/Wiring
04-11-2004 08:46 PM
Quick Reply: power distribution box diagram
