1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F250 Gauge Fuse Blowing
Old 12-22-2004, 08:24 AM
mikesmith706's Avatar
mikesmith706
mikesmith706 is offline
I'm having some issues trying to find out what keeps blowing the #35 Instrument Cluster Gauge fuse on a 2002 F250 Lariat. It blows any range from rite away to 4-5 Days later. Has anyone a clue. I have checked the black/lg wire that runs to the cluster/HEC. Got 18,000 milliAmps. Not good. Thinking its a short to ground. Also got a B1869-RCM....lamp Air Bag Warning Indicator circuit Failure, and B1203-OTC....Fuel Sender Circuit Short To Battery. I am thinking that those are related to when the fuse blows it causes those faults. Any Help is appreciated.
Old 12-22-2004, 09:26 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum. The members in this forum are very knowledgeable about these trucks, they will be by..... and help you with your question.
Good luck with your problems.
Enjoy FTE
Old 01-14-2005, 01:04 PM
mikesmith706
Found problem , was Overdrive wiring chaffed @ shifter, arching out.....
gcvt
12-11-2014 07:24 AM
ff979
12-09-2014 12:34 PM
77F-150
09-02-2013 08:52 PM
sailan
04-14-2011 12:22 AM
xfordtech
05-25-2006 01:22 PM
Quick Reply: F250 Gauge Fuse Blowing
