Camshaft Sensor - Code P0344
the sensor is pretty easy to change, it is just under the a/c compressor at about 10:00 o-clock on the front of the engine. it is held on by a 10mm bolt and has a harness plugged into it. it is easier to get to if you take off the acc. drive belt. if you have an international dealer close you can get one there cheaper than at a ford dealer. i would bring the old one with you to make sure you get the right one. it is covered under the 5 year 100,000 mile warranty and all you would have to pay is the $100.00 deductible (i just let the dealer do it under warranty when mine went out at 35,000 miles)
Is there any chance that they may change any settings to my computer? I realize that if they change anything, then my tuner want work. I also realize that if I change back to the factory settings, that I will loose my error code for them to diagnose the problem, unless it happens again after I reset it.
Originally Posted by Dias
Thanks,
I talked to the dealer where I bought the truck, and they can change it pretty quick. Should I reset my to tuner to stock setting before I let them change it?
rowekmr
02-15-2017 09:26 PM
jnye6625
20
03-07-2007 02:51 PM
