Disc Brake Conversion On 97 F250
Old 12-12-2004, 09:43 PM
barebackjake's Avatar
barebackjake
barebackjake is offline
anybody done this??
Old 12-12-2004, 10:51 PM
barebackjake
no one??
thinking about looking at my wifes superduty to see if theres a way.......
what axle is under a f350 srw 2000
Old 12-13-2004, 10:15 AM
Max1775's Avatar
Max1775
Max1775 is offline
Hopefully someone will reply, I have the same truck and would like to have better stopping power. I also want to go to slotted rotors on the front.
Old 12-13-2004, 12:44 PM
Bigsilver95's Avatar
Bigsilver95
Bigsilver95 is offline
the axle under your wifes 2000 is a 10.5 Sterling rear end, similar to the rear end under your truck. The bolt pattern is different and the abs wont work.
Old 12-13-2004, 08:30 PM
barebackjake
i know the bolt pattern is differnt, its metric im wondering how i could get the abs sensors to work.....if i built a bracket to hold the newer rear rotors.....
Old 12-13-2004, 08:37 PM
Bigsilver95
that is basically what renegade did, i am serious, you should talk to him
Old 12-13-2004, 08:45 PM
barebackjake
renegade??
you out there?????
Old 12-13-2004, 09:35 PM
Bigsilver95
he is on a different site, i will PM ya the addy
Old 12-13-2004, 11:10 PM
eckart's Avatar
eckart
eckart is offline
Check superduty cargo vans they have rear disks and are still the old boltpattern. Boss has a 03 psd van that we where surprised to find has the old 8 bolt patern and not the new metric.
Old 12-14-2004, 08:12 AM
barebackjake
nice thanks eckart hmmm..... is that on a single rear or dual?? the next mission is the brake porportioning valve. i could just use a wilwood valve so i can adjust it but im wondering about brake master compatibility. i know when i put disks on the back of my 85 toyota and my landcrusier i had i needed a diffenrt master. does anybody know what the differnce mechanically the masters are?? does that van have hydralic brake boost or vaccume? is there a parking brake in thoose discs? like whats on the superduty? im pretty sure the abs system is the same its just a hall effect sensor on the rotor with the pick up on the axle.
Old 12-14-2004, 08:32 AM
eckart's Avatar
eckart
eckart is offline
Its a normal bodystyle E350 psd work van with single rear wheels.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: Disc Brake Conversion On 97 F250
