Is there a fast way to clean diamond plate aluminum?
Old 12-12-2004, 08:32 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Powerstrokedlariat is offline
Question Is there a fast way to clean diamond plate aluminum?
I am a contractor in the Northwest and during the winter months my diamond plate tool box really takes a beating. Soap and water aren't really great and I have bought diamond plate polish from the auto store but it takes forever and I usually need several bottles, then in a few weeks it looks crappy again. Any tricks of the trade out there? Thanks in advance.
Old 12-13-2004, 04:24 AM
furball69's Avatar
furball69
furball69 is offline
A 9", 6000 rpm angle grinder with a buff pad and your polish paste would make quick work of it. That's about as close as you can get to a professional job without actually taking it to a pro. Moisten the buff pad with the paste and rub it in a bit because the velocity of the grinder will tend to fling it away. You can try putting small dots of polish on the diamond plate itself but it's probably better to put it on the pad. You can also 'work' the trigger to keep the rpm down a bit as 6000 rpm is a little fast; 3000 - 4000 is plenty if you can find a grinder in that range.
Old 12-13-2004, 10:47 PM
Powerstrokedlariat
Thank you very much, I will give that a try.
Old 12-26-2004, 08:18 PM
rsav's Avatar
rsav
rsav is offline
try a product called 'da bom' we use in on motorcycles, fast easy. go to 'thebomguy.com' best stuff we've ever used.. Roland
Old 12-29-2004, 12:35 PM
Vankaye's Avatar
Vankaye
Vankaye is offline
Save your old buff pads and use them
on the diamond plate. Diamond plate
eats the pad quick.
Old 01-03-2005, 01:59 AM
tofer76's Avatar
tofer76
tofer76 is offline
i just wax mine when i do the truck
Old 01-06-2005, 03:25 AM
volfan945's Avatar
volfan945
volfan945 is offline
mothers chrome polish is the best i have found, leaves a mirror finish
Old 01-06-2005, 07:24 PM
Powerstrokedlariat
Thank you all very much!!
Old 01-06-2005, 08:21 PM
Eric C.'s Avatar
Eric C.
Eric C. is offline
Use the old NAVY standard, BUG JUICE (unsweetened Koolaid the cheaper the better and the cherry works best)and a powered scrub brush. We would sprinkle the powder on the plate wet it a litlle to make it liquid and scrub away. We did this on diamond deck plates in the engine rooms on the des******s using a buffer and all of them shined almost to mirror finish. You can then just wax it to protect it. You can also use real lemon or one of the other lemon juice concentrates. Citric acid is the active ingredient that helps to clean. Just rinse it well anddry it off to to keep from spotting. As long as it doesn't stay on the paint for hours it wont hurt the paint.
Old 01-08-2005, 07:56 AM
dsldandually's Avatar
dsldandually
dsldandually is offline
Napa sells aluminum brightener in spray bottles and gallon jugs you might want to take it out of the truck first as I dont know if its any good for the paintjob it is an acid cleaner and will REALLY clean it then try Never-Dull it is kinda like a giant cotton ball/gauze (sp) that is saturated with something that polishes aluminum like a ****
Old 01-09-2005, 05:55 PM
NBFDCap's Avatar
NBFDCap
NBFDCap is offline
I know this may be too late.... but go to Lowes. In the section where they sell truck boxes, look for a polish called Diamond Brite. It works awesome. We use it on our firetruck and believe me thats alot of diamond plate. Good luck!!
Old 02-18-2005, 02:54 PM
Prplmnsterf150's Avatar
Prplmnsterf150
Prplmnsterf150 is offline
Regular coke or mountain Dew works awesome. All the acid and carbonation just peel the oxidation right off. I use it on my diamond plated toolbox. Soak a sponge in MD then wipe your diamond plate and let the MD sit for about 2 minuites then rinse off with water and dry.
Old 02-18-2005, 05:10 PM
Powerstrokedlariat
Since there is always a supply of coke in the house I will try that first. Next time it is off the truck I will try the brightener from Napa. thanks guys
Old 01-11-2010, 10:26 PM
PFguy's Avatar
PFguy
PFguy is offline
I know this is an old tread, but I work at a gym and we have aluminum diamond plating going all the way around the bottom of the walls. Its oxidized and covered in dried sweat. Will the techniques listed above work for this also? The sweat is caked on in some spots and it wouldn't surprise me if it was 1/8" thick in some of those places. I've tried all the cleaners we have here (pine sol, bleach, amonia, LA's Awesome Cleaner, etc...), including a generic stainless steel cleaner, and nothing seems to work.Thanks in advance.
Old 09-08-2010, 10:18 AM
jeraldfler's Avatar
jeraldfler
jeraldfler is offline
faster
I dont think its as fast as they claim
Quick Reply: Is there a fast way to clean diamond plate aluminum?
