Engine Vacuum
Old 12-12-2004, 10:39 AM
skeleton33's Avatar
skeleton33
skeleton33 is offline
Engine Vacuum
In a flathead 8ba, what is the amount of engine vacuum available? I'm trying to determine if I can use a power booster with disc brakes.
Old 12-14-2004, 07:21 PM
41Clay's Avatar
41Clay
41Clay is offline
I was thinking about this the other day. Is there any if the vehicle isn't moving? Cause the only thing I know creating a vacuum is the downdraft tube. Anyone put on an exhaust vacuum system on one of these? This is a good question.
Clayton
Old 12-14-2004, 10:56 PM
Overkill-F1's Avatar
Overkill-F1
Overkill-F1 is offline
A flathead will have a normal amount of vaccuum 10-20 inches mercury (driving/idle) as measured at intake manifold. I don't see any problem using your brake booster. ...Terry
Old 12-17-2004, 11:52 AM
Steve_B's Avatar
Steve_B
Steve_B is offline
My truck has a 8BA + brake booster fitted
runs fine
Stephen
Old 01-25-2005, 12:35 PM
SteV8e's Avatar
SteV8e
SteV8e is offline
The term "engine vacuum" refers to the difference between outside atmospheric pressure and the amount of vacuum present in the intake manifold. The pistons in the engine serve as suction pumps that create this pressure difference.
Normal Engine Operation: At idling speed, an engine at sea level should show a steady vacuum reading between 14 in. and 22 in. Hg. A quick opening and closing of the throttle should cause the vacuum to drop below 5 in., then rebound to 23 in. or more.
Find a vacuum port on your carburetor or intake manifold and check to insure that you have steady vacuum at the stated levels. If so, your vacuum brake booster will operate properly.
If the vacuum is not steady, the gauge needle behavior tells a story of engine condition. There are charts available to interpret your gauge readings.
ford fisherman
1983 - 2012 Ranger & B-Series
02-03-2015 05:58 PM
dstraw
01-26-2015 11:53 AM
78 & 87 Super Cab
11-07-2013 12:44 PM
64F-100
10-12-2010 12:31 PM
fordblue_ca
08-02-2002 01:49 AM
Quick Reply: Engine Vacuum
