Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
powerstroke repair?
Old 12-11-2004, 11:36 AM
4x4k20's Avatar
4x4k20
4x4k20 is offline
powerstroke repair?
anyone know of someone who knows how to repair the powerstroke diesel in the ga. area? i have 2 f550s that are running bad . i need someone that will come out and do the repairs. i would carry them back to ford but they take too long.
Old 12-11-2004, 04:54 PM
jharvey3's Avatar
jharvey3
jharvey3 is offline
4x4k20 Welcome. When you say that they are running rough can you give us some description of how they are running? Rough encompasses lot's of things, hard starts, no start when warm, crappy mileage, no power, etc Next where are you located in Ga.
John
Old 12-11-2004, 05:06 PM
4x4k20's Avatar
4x4k20
4x4k20 is offline
hi i have one truck that wont start in the mornings but after you do get it started it cranks fine. no service eng. light comes on.. the other runs rough with the check eng. light on... located 15 miles south of the atlanta airport
Old 12-11-2004, 06:47 PM
jharvey3's Avatar
jharvey3
jharvey3 is offline
Does the one that won't start in the morning start ok if you plug in the block heater for a couple of hours? If so then I'd say you got a glow plug system issue, more than likely the relay itself. On the other one can you get the codes scanned? AutoZone will scan it for free as a rule. This would help in diagnosing it's problem and give us an idea where to start looking for troubles. Also I forgot to ask what year model are these trucks?
John
Old 12-11-2004, 10:52 PM
old87's Avatar
old87
old87 is offline
Jharvey- master of all that is diesel .
Can they really run on fuel oil? And cookin' oil??
Old 12-12-2004, 06:07 AM
jharvey3's Avatar
jharvey3
jharvey3 is offline
Yepper, check the alternative fuels forum here and on TDS. Should be converting mine to veggie oil in a couple of 3 months.
John
Old 12-14-2004, 07:53 PM
jharvey3's Avatar
jharvey3
jharvey3 is offline
4x4k20 talk to us man...did you get the PSD's running ? Enquiring minds need to know.
John
Old 12-17-2004, 02:02 PM
Ladyfire3374's Avatar
Ladyfire3374
Ladyfire3374 is offline
John,
Where are you getting the veggie oil?
Me & an engineer friend have been toying with doing a conversion, but he doesn't want to use his diesel Mercedes. We've considered getting a clunker just to mess with, but we're both a little broke. Are you using one of the kits or rolling your own?
Old 12-17-2004, 02:35 PM
jharvey3's Avatar
jharvey3
jharvey3 is offline
Ladyfire I'm not running veggie yet, but probably will after March or April, I have some friends that are making their own Bio-D for use in their Cummins though, best place to get it is from chinese resturants, they change their oil frequently so it's usually cleaner than say , burger doodle or mac-yucks. When I do convert I will look real hard at the Greasel system.
John
Old 01-13-2005, 08:10 PM
old87's Avatar
old87
old87 is offline
John
Yep, them cats and armadillo cook up real clean..
brown78
08-24-2016 12:20 PM
Shaneb75
01-02-2015 11:20 AM
makuloco2000
1999 to 2016 Super Duty
08-31-2014 05:26 PM
41- powerstroke
03-15-2008 08:39 PM
Quick Reply: powerstroke repair?
