ABS Light on 2001 Ranger
Take the truck to the dealership and tell them to fix it under the factory warranty. We had a similar problem with the 2001 Ranger we have at work. The light started flashing intermittently at first, and then stayed on whenever the engine was running. Didn't notice any driveabilty problems, though. We took it to the dealer, and found out a wire going into the clock spring was shorting out. Hasn't come on since then.
The problem you describe could be a faulty ground circuit. I am an industrial service tech and have seen a similar problem in older relay logic machines. When the ground or return circuit is broken then then the power will sometimes find another path to ground. When that new path is thru a relay coil the circuit will oscillate. In your case it flickers which could be the same type of oscillation.
Mason
Mason
1981fordstepside
06-21-2014 01:11 PM
IDIDieselJohn
01-08-2014 10:58 PM
