1993 Ranger rear end swap
Currently my 1993 Ranger (2.3L) has a 7.5" rear end with a coventional differential. I have heard that same year Ford offered a Traction-lok(sp?) rear end. I am also told the 1995 rear end is interchangeable. Does anybody know if either of these things is true? If so how hard is it to swap them out? I live up north in South Dakota and I can't get around half the time in my Ranger but I can't afford a new truck right now. Thanks for the help
Greetings:
The rear ends do interchange, but be cautious about what you come across. Read the codes and make sure you are getting an appropriate gear ratio. The owner's manual will tell you how to figure out which rear end ratio you have. When the pinion shaft sheared in my '83 4 cylinder Ranger (quite a surprise given that it was hardly a torque monster), the wizards at my garage stuck another rear end in - it was obviously completely wrong for my engine and transmission. I couldn't use fourth gear unless I was going at least 60 mph. My '90 2.9 also easily spins the rear tires and my NEW garage says that there is a kit which will convert what I have to a locking axle. This would cost about $600 CDN. Given that the truck has 315,000 km on it, I have decided to go with an old lateral file cabinet in the back and a little less peddle now that things are getting slippery. Make sure you know what you're buying before you lie in the mud to change the rear end out. The wrong gears really spoiled my '83.
kentuckyredneck
01-06-2014 06:59 AM
Oxfordrider
38
11-05-2012 11:51 AM
