Ford's C6 hd pinion set
Old 11-28-2004, 07:21 PM
tastyklair's Avatar
tastyklair
tastyklair is offline
Has anyone here used the Ford HD 6-Pinion wide ratio gear set kit. Ford racing lists it and says
"This kit adapts gear train componennts from the new 4r100 trans to all c6 trans. The 6 pinion planet assemblies provide 2.72:1 low and 1.54:1 intermediate ratios as the discontinued m-7398-c gear set, while increasing torque capacity by 43%. Kit includes the hd #5, #7, #8, and #9 needle bearing components. Provides drag racers with more acceleration and tow vehicles or motor homes with more pulling power without changing axle ratios. Note: No machining is required on m-7398-f kits!"
What differences have you noticed if any one has used this. What are the stock ratios in my 79 c6?
Old 11-28-2004, 08:17 PM
SoCalDesertRider's Avatar
SoCalDesertRider
SoCalDesertRider is offline
I haven't used the kit. I have looked into it though. Stock C6 ratios are 2.46, 1.46, 1.00.
rat_6
02-03-2016 03:55 PM
scarey1
Ford Truck Parts for Sale
09-14-2015 10:41 PM
jaker65
Large Truck
08-28-2015 04:52 AM
David85
31
04-27-2008 04:52 PM
Quick Reply: Ford's C6 hd pinion set
