how much does F150 weigh empty?
Old 11-24-2004, 10:29 PM
fordtruck88's Avatar
fordtruck88
fordtruck88 is offline
I have a 1994 F150 reg. cab, long bed with the 300 I-6, 5 spd manuel and no a/c or power options. does anyone know about what this truck would weigh empty?
thanks
Old 11-24-2004, 10:39 PM
engineguy's Avatar
engineguy
engineguy is offline
I have a '92 Nite regular cab short box with a 302 5 speed and it weighs 4100lbs with a half tank of fuel(in one tank) and no spare tire.
Old 11-24-2004, 11:19 PM
larry derouin's Avatar
larry derouin
larry derouin is offline
My 93 Short bed, extended cab,4x2, 4.9, E4OD weighs 4500#(+/-100
#) with front tank full and rear tank empty. I imagine yours would weigh about 4300 give or take a 100 or so.
Take it to your local landfill and get it weighed in and out. Subtract your weight and viola!!!
It should weigh between 4000-4500.
Larry
Old 11-25-2004, 06:51 AM
MustangGT221's Avatar
MustangGT221
MustangGT221 is offline
My F-150 has a good amount of weight added to it (lift kit, 35" tires, misc items that add up quickly) and at the dump it weighed in at about 5300. After my 393/zf/1-ton axle swap, it should be close to 6000.
There are sooo many variables with these trucks that it's pretty much impossible for us to tell you what it weighs, ballpark is difficult too, but my guestimate of your truck's weight is like 4600ish. I think we all know the only real way to know is to have it weighed...
Old 11-25-2004, 07:16 PM
phoneman71's Avatar
phoneman71
phoneman71 is offline
My 1992 F150 XLT,5.0/5sp manual, 4x4 regular cab/short box weights 4425 pounds--with spare tire and full tank of gas. With factory skid plates. 235/75x15 tires.
I was surprised it weighed that much--I was expecting about 4100 pounds.I believe that the 4x4 system adds about 250/300 pounds over the 4x2 version.
Old 11-26-2004, 03:58 PM
Frank Lang's Avatar
Frank Lang
Frank Lang is offline
My 1988 F150 XLT Lariat, 4 x 2, 302, auto, 3.55 LS, extended cab with shortbed, with a canopy weighs 5,100 lbs. according to the truck weigh scale. How much difference does the extended cab and the canopy each make?
Frank.
Old 11-26-2004, 05:40 PM
tellico's Avatar
tellico
tellico is offline
Go weigh it at your county dump..
1979 fi50 4x4 with me in it(200lbs)-5180
1990 f350 4dr dually with me in it(225lbs)-6800
Old 11-27-2004, 01:30 AM
optikal illushun's Avatar
optikal illushun
optikal illushun is offline
im gunna say in the neighborhood of 4100-4300 lbs. it depends if ur in it, how much fuel u have, what other stuff u have inside it, etc...
Old 11-27-2004, 04:33 AM
MustangGT221
Since he has a reg cab, but long bed....he is probably over 4100-4300, that figure sounds a little low, which was why I guestimated 4600...
Just go to your local dump and have it weighted I guess......
Old 11-27-2004, 10:04 AM
Dr_Sin's Avatar
Dr_Sin
Dr_Sin is offline
I got an 89...same specs as you...I weigh in at 4500 to 4600 everytime i hit the scales...And since I'm building a few hundred feet of stone walls in my yard..I'm at the scales very often...
Paratrooper84
6.7L Power Stroke Diesel
43
02-24-2018 10:19 PM
BlackFX4Screw
2004 - 2008 F150
49
11-19-2015 08:49 AM
jerem0621
2004 - 2008 F150
06-16-2013 11:56 PM
scottman70
EcoBoost (all engine sizes)
18
09-03-2012 09:32 AM
Catch This
1999 to 2016 Super Duty
16
11-16-2008 07:35 PM
Quick Reply: how much does F150 weigh empty?
