1996 Ford Ranger XLT, 3.0 V6
My Ranger has a problem with warm temp starts. In the morning when it's cool it starts no prob. After work I go to start it and it refuses me. It turns over no prob and attempts to kick in. Sounds like it burns up the vapor in the lines and that's it. There's no pressure at the test port. I have no desire to dig into the tank just yet to rip out the pump (it's almost full). Anyone have any ideas as to why I'm not getting the fuel I need when it's time to go home? I work on Corporate Jets and know something about environmental factors like temperature extremes, but, since I know little about the interworkings of todays computerized vehicles, I am in much need of help. Oh ya! This is a great site! Big Thanks to those who have made it what it is!
Since you know that you don't have fuel pressure when it won't start it can be either a fuel pump problem or electrical problem. Listen the next time it won't start to see if you hear the pump run when you turn the key to on. If you don't hear it check for power to the pump, you might want to have someone help you since the pump times out in a few seconds. If you don't have power, check it out at the inertia switch, also look at the relays. If the pump does run, but still no pressure look at the filter. If you have to do the pump it's easier to pull the bed rather than dropping the tank.
joeKyTN
1983 - 2012 Ranger & B-Series
05-19-2012 10:28 PM
the78ranger
03-17-2011 07:35 PM
