400 Cylinder Head Casting Numbers
Old 11-17-2004, 05:35 PM
Mud Rat's Avatar
Mud Rat
Mud Rat is offline
Question 400 Cylinder Head Casting Numbers
I have two heads for the 400.
One casting number is D5AE-A2A, the other is D5AE-A3A.
Are there differences between the two?
Old 11-17-2004, 05:52 PM
74 F100 351m's Avatar
74 F100 351m
74 F100 351m is offline
:-x25 ??????????????? :-x25
Old 11-17-2004, 07:46 PM
BrentKasson's Avatar
BrentKasson
BrentKasson is offline
My guess would be different years maybe, or perhaps casting places. I think i saw that all cylinder heads on the 400 were the same from 75 on? Check out bubbaf250's website. Good info there.
Old 11-18-2004, 07:44 AM
Donnie Knight's Avatar
Donnie Knight
Donnie Knight is offline
I think this link may supply you with some info, http://home.earthlink.net/~bubbaf250/parts/pics03.html
Old 11-18-2004, 02:43 PM
squirrelhunter's Avatar
squirrelhunter
squirrelhunter is offline
Smile
Both heads are 74.5 cc. They are 77-later 351M/400
Old 11-18-2004, 03:26 PM
beartracks's Avatar
beartracks
beartracks is offline
The first two digits indicate decade and year. In this case 1975. I believe the factory tolerance for 2V heads was 78 to 80cc.
Old 11-19-2004, 07:54 AM
Bill_Beyer's Avatar
Bill_Beyer
Bill_Beyer is offline
The A2A & A3A are engineering revison #s. I don't know of any place to find out exactly what was changed but I'd suspect they're virtually identical. I wouldn't hesitate to use them on the same motor.
Old 11-19-2004, 12:19 PM
beartracks's Avatar
beartracks
Compare the exhaust passages and the area around the exhaust valve seat. Look for the air injection boss "bump" and a restricted exhuast port.
Old 11-21-2004, 11:22 PM
Matts72's Avatar
Matts72
Matts72 is offline
Yes there were two different heads for the 400...
They are the same as far as chambers and valves go...
The difference is that one has a rotator thingy on the exhaust stem, the other one doesn't.
srsbjohnson
08-06-2013 04:28 PM
fordlowboy
10-31-2002 10:28 PM
skud
01-26-2001 06:22 PM
tmod
05-21-2000 10:44 AM
Quick Reply: 400 Cylinder Head Casting Numbers
